Valve schematic & PC board design
Old 8th August 2004, 08:30 PM   #1
Athol is offline Athol  New Zealand
Send a message via AIM to Athol
Default Valve schematic & PC board design
Has any one come a cross a good program that is user friendly and allows you to draw schematics using valves. Also the same but for designing PC boards for valves? There is a vast range out there and little in the way of a survey to recogmend which are worth looking at.
Comments would be appreciated.
Old 9th August 2004, 06:52 AM   #2
planet IX is offline planet IX  Germany
Send a message via MSN to planet IX
G'day Athol,
with EAGLE you can easily draw schematics and convert them into a pcb;
I didn't find a english website, but the programm is in english
(free demo-download; free libraries download incl. tube-library
cadsoft
Old 9th August 2004, 08:23 PM   #3
Thanks planet 1X
will have a look at what you suggest
regards Athol
Valve schematic & PC board designHide this!Advertise here!
What to read on SS amp design? (valve-ish style) Nevod Pass Labs 1 27th August 2008 07:16 AM
A building block approach to valve amp design gingertube Tubes / Valves 10 28th July 2008 02:48 AM
phono preamp design for c3m postie valve fergs1 Tubes / Valves 1 29th May 2005 02:12 PM
Tried and tested clone or design for 10w valve amp. kazino21 Multi-Way 6 4th March 2005 05:48 PM
