Tweeks on tubes - bring out the demagnetiserss
Old 2nd August 2004, 09:29 PM   #31
On Hiatus
SY's Avatar
Default OT, sorry
She WAS a babe, wasn't she? And one of the few signs that there is still any sanity left in France. But I got some pressure from one of the other forum members to change her out, so here you are, H.L. Mencken.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 2nd August 2004, 10:06 PM   #32
John Swenson is offline John Swenson  United States
Hello all, I'm the one that started this whole mess with my beam deflection tube preamp. After I posted information on it, one of the other members mentioned that these tubes are very sensitive to magnetic fields and that sometimes they get magnetized which can cause performance effects. I decided to try this out. I made a demagnetizer out of a spool of wire and a 6.3V transformer and attached the tubes to a plastic tube and slowly moved them through the field.
The spectrums I posted were two representave ones out of many that I did. By the time these were made the tubes had been in and out of the sockets at least 4 times so it was not initial "pin cleaning". They had been "burning in" for several days. Every time I do a spectrum I turn on the tubes and let them sit for 15 minutes to have some form of standardization. For both before and after demagnetization I ran several spectrums over a period of an hour. Of course there were small differences between runs but they were much less than the differences between pre and post demagnetization.
I perfromed this on the two tubes I had and got similar results for both. Not identical but similar.
Note, the spectrums were for BEAM DEFLECTION TUBES, not regular triodes or pentodes. I am NOT saying the same thing is going to happen with a 12AX7.
Other people have decided to try this demagnetizing thing on "normal" tubes and some have found a sonic difference. I myself have not tried this so I can't comment on what effect it has.
Since the Initial trials I have done the demagnetizing thing on 4 more BDTs, on two of them there was a significant change, on the others there was not very much of a change. All 4 of these tubes were GE, but two of them were in slightly shorter boxes than the others and had nice clear markings, the other two had somewhat deteriorated markings. I got the impression that two of them were much newer than the other two, so either manufacturing changes had taken place or the two older ones had been magnetized more by sitting around in the same location for a longer period of time. I did not perform exhaustive tests on these, that wasn't the goal, I'm trying to get good sound not a thesis.
Given that I can clearly hear a difference when demagnetizing on some tubes I'm going going to continue doing this when I get new tubes. So far the sample is pretty small (6 tubes) so I have not come up with any way to know in advance which will benefit from the procedure so I'm going to continue performing it on any new BDT tubes I get. It takes only a minute to perform and CAN make a big difference.
John S.
John S.
Old 2nd August 2004, 10:19 PM   #33
On Hiatus
SY's Avatar
John, many thanks for the follow-up!
Old 3rd August 2004, 03:56 PM   #34
jneutron is offline jneutron  United States
jneutron's Avatar
John S.
And a fine mess you've gotten us into....thanks a lot, John...
Um, John? what is a beam deflection tube? Sounds like it relies on beam steering for amplification, instead of the pinching of the stream... (I know, I know..simple question...problem is, I lost my near and dear RCA tube manual back in, I think, '74..I'm lost without it..)
In all your trials, did you try magnetizing any tubes to see if you could make it worse?
Cheers, John (oh no..not another one..)
I hate all these smart gadgets..I refuse to buy things that are smarter than me. I've made a list of those things... Cabbage just made the list.
Old 3rd August 2004, 04:56 PM   #35
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Beam deflection tubes use electrostatic deflection, 7360 I think is one of them (among other types in the 6V heater range). Popular among shortwave radios because you can modulate/demodulate SSB with them.
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 3rd August 2004, 05:11 PM   #36
jneutron's Avatar
Tim
Thanks Tim...those things can certainly be altered by magnetic fields...
I figured only my tv set worked like that...well, ok...that and the particle collider rings I build magnets for..
Cheers, John
Old 3rd August 2004, 05:34 PM   #37
smoking-amp is offline smoking-amp  United States
smoking-amp's Avatar
Default Beam Deflection Tubes info
"what is a beam deflection tube"
http://basenjes.de/tubes/images/6ar8/6ar8.htm
and general tube design:
http://www.mif.pg.gda.pl/homepages/f...D62/index.html
http://www.mif.pg.gda.pl/homepages/f...RCA/index.html
Don
Tweeks on tubes - bring out the demagnetiserssHide this!Advertise here!
Marantz PM66 KI tweeks Fidelity Audio Solid State 519 21st June 2017 12:51 PM
Quad II Mods/Tweeks slurb.net Tubes / Valves 62 16th June 2012 12:32 AM
expert tweeks for PA? Pbassred Multi-Way 4 7th December 2003 08:57 PM
Copyright ©1999-2017 diyAudio
