Best place to place bleeder resistor in a power supply? Best place to place bleeder resistor in a power supply? - diyAudio
Old 29th July 2004, 01:13 AM   #1
G is offline G  United States
G's Avatar
Default Best place to place bleeder resistor in a power supply?
The below image is a PSU I am modeling for my preamp. I would like to place a 220K bleeder resistor in the PSU but I'm unsure where to put it. Does it matter?
Gavin
Old 29th July 2004, 01:34 AM   #2
Eli Duttman is offline Eli Duttman  United States
Gavin,
The purpose of bleeder resistors in PSUs employing cap. I/P filters is to discharge the caps. when the unit is powered down.
R3 will discharge C4, at a minimum. Put the 220 K part across C3, as that will surely discharge C1, C2, and C3.
BTW, please explain the purpose of a current source connected from B+ to ground. I'm scratching my head.
Eli D.
Old 29th July 2004, 01:37 AM   #3
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Does it matter?
Basically that depends on how safe you want to play it...
As you have a choke and some resistors in series with the B+ line, I'd put a bleeder across all the caps.
By doing so you'd still discharge the B+ reasonably fast enough not to get killed by unexpected high voltage present on one of the caps.
As you want to use a 220K resistor and you have 4 caps, I'd wire a 1M resistor across each of the caps.
Frank
Old 29th July 2004, 01:43 AM   #4
G's Avatar
Originally posted by Eli Duttman
Gavin,
Duncan's PSU designer won't let you put a resistor in parrallel with the load. So I put in a current tap to simulate a 220K resistor in parallel. At least that's what I had in mind.
Gavin
Old 29th July 2004, 01:44 AM   #5
G's Avatar
As you have a choke and some resitors in series with the B+ line, I'd put a bleeder across all the caps.
I can do that.
Gavin
Old 29th July 2004, 02:03 AM   #6
fdegrove's Avatar
Eli,
R3 being the load, i.e. the circuit itself, the value goes up as the unit is powered down.
In all fairness it will likely discharge the lot quite fast enough under normal circumstances but...
I've seen people pulling the tubes out of their units, powering down and, without bleeder resistors put where they belong, being quite amazed at seeing their soldering iron fried by touching a closeby cap with it....and that's the happy ending for you...
Frank
Old 29th July 2004, 03:26 PM   #7
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Um...
What's the purpose of everything past C2, aside from the loads?
No wonder you want a bleeder resistor. For that much capacitance (suitable for filtering a good 500mA) you'll need almost as much as your 12k load resistor there, maybe 20k. Such will reach 99% of operating voltage in about a minute (five time constants), assuming your load turns off instantly (which it doesn't. Adding that in, it might take 20 to 30 seconds.)
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 29th July 2004, 05:35 PM   #8
pedroskova is offline pedroskova
RIP
pedroskova's Avatar
If you are planning on biasing up your heaters with dc from your B+, the voltage divider that you use will act as your bleeder. Just be sure that it's at the end of your B+ supply.
Old 29th July 2004, 06:17 PM   #9
G's Avatar
Excellent point! Thanks. One less thing to worry about.
Gavin
Old 30th July 2004, 07:43 PM   #10
cliffhiker is offline cliffhiker  United States
As long as the primary will sustain the voltage... here's a great way to bleed it quickly that I've used on low voltage supplies
http://www.reed-electronics.com/ednm...es/70501di.pdf
or
http://www.reed-electronics.com/ednm...bestofdi_power
Best place to place bleeder resistor in a power supply?Hide this!Advertise here!
2x 2Sk170 in place of 2SK389 and 2x 2SJ74 in place of 2SJ109? jarthel Parts 20 27th July 2016 07:11 AM
Bleeder resistor! lanchile Chip Amps 15 24th February 2009 10:06 PM
Power Amp P.S. Bleeder Resistor Reg? fastcat95 Solid State 2 28th April 2008 05:10 AM
EL34 in place of a 6AS7G (used in the supply circuit as a pass tube). how? jarthel Tubes / Valves 27 9th June 2006 12:04 AM
bleeder resistor for ZenV4 power supply; and ancllary matters Zapped Pass Labs 13 24th September 2003 04:02 AM
Copyright ©1999-2017 diyAudio
