Best place to place bleeder resistor in a power supply?
Old 31st July 2004, 02:18 PM   #11
G is offline G  United States
G's Avatar
Originally posted by cliffhiker
As long as the primary will sustain the voltage... here's a great way to bleed it quickly that I've used on low voltage supplies
http://www.reed-electronics.com/ednm...es/70501di.pdf
or
http://www.reed-electronics.com/ednm...bestofdi_power
A profoundly clever, yet simple, idea! Thank you.
Gavin
Old 1st August 2004, 09:12 AM   #12
jueic is offline jueic  Taiwan
Originally posted by Eli Duttman
Gavin,
The purpose of bleeder resistors in PSUs employing cap. I/P filters is to discharge the caps. when the unit is powered down.
Other than dischaging the caps, the bleeder resistors main purpose should be providing the minimum load current for chokes.
Minimum Current= 2*1.414*Vin /6Pi *pi *f *L
Choke can not operate correctly if the current falls below the min value.
Old 4th August 2004, 01:17 AM   #13
cliffhiker is offline cliffhiker  United States
You are entirely correct,
However, nothing precludes using both approaches when appropriate.
Allows selection of minimum bleed resistor to maintain minimum load current for the choke (when a choke is used),
and
A lower resistance to safely and quickly discharge upon turn off.
Old 4th August 2004, 10:26 AM   #14
morfeas is offline morfeas  Greece
Contacting a small value bleed resistor on power off gave a big thumb on my power amp.
Best place to place bleeder resistor in a power supply?Hide this!Advertise here!
2x 2Sk170 in place of 2SK389 and 2x 2SJ74 in place of 2SJ109? jarthel Parts 20 27th July 2016 08:11 AM
Bleeder resistor! lanchile Chip Amps 15 24th February 2009 11:06 PM
Power Amp P.S. Bleeder Resistor Reg? fastcat95 Solid State 2 28th April 2008 06:10 AM
EL34 in place of a 6AS7G (used in the supply circuit as a pass tube). how? jarthel Tubes / Valves 27 9th June 2006 01:04 AM
bleeder resistor for ZenV4 power supply; and ancllary matters Zapped Pass Labs 13 24th September 2003 05:02 AM
Copyright ©1999-2017 diyAudio
