Preamp:  Foreplay or 5687 or 12B4
Old 3rd August 2004, 04:40 AM   #21
zobsky is offline zobsky  India
zobsky's Avatar
Originally posted by Toyman_PA
To make it short, in your opinion will the power supply in post #14 work well with your 12B4 linestage? By working well, I mean good sound, not necessarily as good as your new PSU designs. But something that I can learn on and expand on in the future.
Thanks again for your time,
Toyman
I'm no Frank, .. but if you want a one word answer, ..it's probably YES, ..IMHO (and may the god of lightening smite me down tonight if I'm wrong )
.. if you want a barebones silent PSU, .. one choke should do the trick (as per my novice work with PSUD on this design)
"Not everything that can be counted counts, and not everything that counts can be counted." - Albert Einstein
Old 3rd August 2004, 12:29 PM   #22
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
I tried my own on post #14 by taking an existing 250V and trying chokes with diff resistance ratings to get to ~260V.
First of all, I don't think 10VDC less will make the circuit sound bad....
Still, if you want an extra 10VDC then you can put just a small cap right after the rectifier(s), start with something as small as 1F and raise or lower the value until you get the desired result.
At least that's the best compromise I can come up with.
Sure. Expansion possibilities will depend on the real estate and pecunia available, that's one of the beauties of DIY, isn't it?
Frank
Old 3rd August 2004, 12:43 PM   #23
Toyman_PA is offline Toyman_PA  United States
Thanks Frank and Zobsky. I appreciate your honest opinions and help. I will be back with some questions after I build the PSU and cant get it to work. Take care and thanks again.
Toyman
Old 3rd August 2004, 01:31 PM   #24
zobsky's Avatar
as you begin to consider the construction details, .. think about the physical layout and space for possible mods.
IIRC, .. it is also recommended that the power tranny and the choke are at 90 degrees in the horizontal plane to minimize interference
good luck!
Old 4th August 2004, 04:10 PM   #25
Brett is offline Brett
Brett's Avatar
Default 12B4A
Works for me..........
Preamp:  Foreplay or 5687 or 12B4Hide this!Advertise here!
Foreplay Preamp volume popping arc2v Tubes / Valves 7 22nd August 2007 03:04 AM
My ForePlay Processor Controlled Preamp Algar_emi Tubes / Valves 34 14th December 2005 05:38 PM
12B4 Battery Bias from (Preamp: Foreplay or 5687 or 12B4 ) DougL Tubes / Valves 3 2nd August 2004 06:06 PM
Pics of Foreplay Preamp TubeHound Tubes / Valves 16 5th February 2003 01:29 PM
Tube preamp similar to Foreplay JAZZ2250 Tubes / Valves 6 10th December 2002 10:14 PM
