Is there a 'Gainclone' Of the tube world?
Old 27th July 2004, 04:24 AM   #1
PHilgeman is offline PHilgeman  United States
PHilgeman's Avatar
Send a message via AIM to PHilgeman
Default Is there a 'Gainclone' Of the tube world?
I dont mean to offend with the title, but I am curious.
Good performance, from a handlful of parts. Reasonable cost and a trusted, well published design?
So... $150 for a stereo amplifier excluding connectors and chassis.
About 5-10W
Less than 20 parts per channel
Thanks,
Paul Hilgeman
Old 27th July 2004, 04:28 AM   #2
G is offline G  United States
G's Avatar
Default Re: Is there a 'Gainclone' Of the tube world?
About 5-10W
Thanks,
Paul Hilgeman
You can build a Decware Zen amp clone for about $150 if you buy one of those old Single Ended EL84 console amps on Ebay. The output transformers aren't much to brag about but they sound pretty good.
http://cgi.ebay.com/ws/eBayISAPI.dll...710861477&rd=1
Gavin
Old 27th July 2004, 05:36 AM   #3
rcavictim is offline rcavictim  Canada
rcavictim's Avatar
I am aware that "Gainclone" refers to a dirt simple audio amp using a chip and just a few discrete components on a heatsink of your choice that has become popular for some reason that escapes me, but the name makes absolutely no sense to me. Can anyone explain this?
Maybe they should have called it "Gainsurprise" because after all the negative feedback necessary to make the solid state thing linear enough to actually listen to, when they found that they still had some gain from a single chip they were surprised.
Why not call a simplified one tube audio amp "amp in a bottle", "tone in a bottle",..... anything but that other name.
"There are more worlds than the one you can hold in your hand." Albert Hosteen, Navajo spiritual elder and code-breaker, X-Files TV Series.
Old 27th July 2004, 06:26 AM   #4
DougL is offline DougL  United States
Here is a simple Tube amp. Two tubes.
http://www.svetlana.com/graphics/TB/No10fig4.gif
A little 10 watt amp. There are many simular EL84 amps on the web.
Doug
Old 27th July 2004, 07:06 AM   #5
rdf is offline rdf  Canada
rdf's Avatar
Originally posted by rcavictim
......but the name makes absolutely no sense to me. Can anyone explain this?
It's a clone of a commercial product called a Gaincard.
Still too complex! How about a Mullard 3-3: single ended, two stages, one capacitor in line? There are also a few one-tube amps floating around.
Re: the original post, I don't know if there really is a true equivalent to the Gaincard/clone concept floating around. It would require a small, complex, tube-fueled generic gain block surrounded by a handful of components. The closest I would think are the triode/pentode dual tubes designed as driver/output pairs.
Old 27th July 2004, 09:18 AM   #6
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
My Revision 3 (see sig), but I'm as biased as the 6L6.
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 27th July 2004, 12:38 PM   #7
audiousername is offline audiousername  Australia
audiousername's Avatar
The simplest valve amplifier i have come across is based on the 6S45PE (6C45piE in cyrillic) triode for a whopping 1400mW(!) of power. I know this is a rather, no VERY limited in SS circuitry but some of the most expensive, rare and coveted valves only produce about that much power single ended. Fortunately this valve isn't rare and can be had pretty cheaply. See http://digilander.libero.it/paeng/projects_frame.htm and click on ST-AMP under the power amplifiers heading in the left frame. I have attached the schematic to the amplifier below... the red circled bit is the signal circuitry - 6 parts! - I believe this is less than most of the the gaincard/gainclone amplifiers. More power can be had by paralleling these valves, or arranging them in push-pull (more complicated) - I had some schematics for these... i will post them later when i find them.
A more complicated iteration can be found here http://www.valvediy.com/kugelispg1.html and may or may not yield better results - (is simpler always better?)
Anyways, valve circuits aren't usually terribly complicated or containing too many parts - particularly the single ended ones. The 6S45PE valve is actually often used as input/driver valve for more powerful valves. So, anyone who built the amp above could probably reuse the valve and some of the parts in a new amp for more power by adding another more powerful valve behind it.
Here is a circuit using it to drive a 2A3 for 3-4W of power http://home.earthlink.net/~jeremyepstein/freelunch.htm It probably uses about 10 parts in the signal circuitry - haven't counted. Most 2A3 circuits don't use such a high power supply voltage (B+) but this one 'stacks' the power supply for both valves, using the idle current from the output valve (2A3) to supply the input valve (6S45PE), and also uses direct coupling (no capacitors between valves)
For even more power, one can use a transmitting valve such as the 211, although these require horrendously high voltages (sometimes more than 1kV) - see the SE211-6C45 under the power amplifiers heading from the first link in this post.
This being said, all valve circuits use high voltages (much more than the +/35V for an LM3875!) and hence extreme care must be taken. Using 500V or 1000V in the higher powered circuits i mentioned really has to be left to people experienced and confident with high voltages. Death is very permanent and electrocution is a horrible way to get there. Sorry to be so morbid but it's the truth.
Old 27th July 2004, 01:22 PM   #8
Default attached schematic
aargh... the attachment didn't come out properly. It would probably have been a violation of copyright anyway. See it on the link if u want
Old 27th July 2004, 04:30 PM   #9
woody is offline woody
But I must 2n`t that. The 6c45pi is a sweet , sweet tube (true it`s construction, using a titanium plate and a platium grid is a little different, but it sure sounds good!!!) Read that again, Titanium plate and Platimun grid..... I just wish it had a big brother!
Woody
Old 27th July 2004, 05:11 PM   #10
ThorstenL is offline ThorstenL  Germany
Previously: Kuei Yang Wang
Konnichiwa,
About 5-10W Less than 20 parts per channel
Not quite there, but close would be a "El Cheapo" version of the Maurits be Mr. Van Der Veen. You can use fairly inexpensive Mains torroid as output transformers with good results (not the least because of the low anode impedance of the 6AS7) as well as a simple mains insulation transformer and a simple LT transformer or two LT Transformers back to back to generate the Supply Voltages. Part count is fairly low too.
I have been idely working on a modified design with a few neat tricks and reduced parts count, to be build and published eventually, when I get enough time....
In the meantime:
http://www.diyaudio.com/forums/showt...756#post351756
http://www.triodeguy.com/6as7_pp.htm
Maybe this will get you going?
Using a pair of pretty high powered 12V+12V secondary mains transformers, one to give heating (6AS7 Heaters in series) and the second transformer "back to back" to give around 230V AC stepped back up from the 12V+12V and you have your supply sorted. If you buy surplus mains transformers you should be well within your budget.
Sayonara
Is there a 'Gainclone' Of the tube world?Hide this!Advertise here!
Seek for your comments/advice to newbie on Tube world afriend Tubes / Valves 6 30th August 2006 07:00 PM
Gainclone vs tube navin Chip Amps 33 21st February 2006 05:47 AM
HK & world: with Cayin, are tube kits still good value (apart from learning)? rick57 Tubes / Valves 11 10th May 2005 04:51 PM
FOR SALE World Audio Tube Amp bart_dood Swap Meet 0 17th February 2004 02:28 AM
Suggestions from the tube world rick57 Tubes / Valves 16 18th July 2003 11:27 AM
