Is there a 'Gainclone' Of the tube world?
Old 28th July 2004, 02:38 AM   #11
PHilgeman is offline PHilgeman  United States
PHilgeman's Avatar
Send a message via AIM to PHilgeman
Thanks Guys
Old 28th July 2004, 03:50 PM   #12
Mike L. is offline Mike L.  United States
The simplest valve amplifier i have come across is based on the 6S45PE (6C45piE in cyrillic) triode for a whopping 1400mW(!) of power. I know this is a rather, no VERY limited in SS circuitry but some of the most expensive, rare and coveted valves only produce about that much power single ended. Fortunately this valve isn't rare and can be had pretty cheaply.
Where is this valve available. I can't seem to find any reference to it at any of the usual sources in the U.S..
Thanks.
Mike L.
Old 28th July 2004, 04:18 PM   #13
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
No idea if this counts as such...........:
UNCLE NED'S TUBE STASH...
Frank
Old 5th August 2004, 10:37 PM   #14
Sheldon is offline Sheldon  United States
Originally posted by audiousername
The simplest valve amplifier i have come across is based on the 6S45PE (6C45piE in cyrillic) triode for a whopping 1400mW(!) of power. I know this is a rather, no VERY limited in SS circuitry but some of the most expensive, rare and coveted valves only produce about that much power single ended. Fortunately this valve isn't rare and can be had pretty cheaply. See http://digilander.libero.it/paeng/projects_frame.htm and click on ST-AMP under the power amplifiers heading in the left frame. I have attached the schematic to the amplifier below... the red circled bit is the signal circuitry - 6 parts! - I believe this is less than most of the the gaincard/gainclone amplifiers. More power can be had by paralleling these valves, or arranging them in push-pull (more complicated) - I had some schematics for these... i will post them later when i find them.
Interesting little amp. If you were to build this thing, would you use separate LC stages for each channel? Looks like one PS for both channels in his schematic.
Sheldon
Old 6th August 2004, 11:21 AM   #15
Brian Clark is offline Brian Clark  United Kingdom
Brian Clark's Avatar
For a similar amp - and one that has been tried and tested by several people around the world - see
The Great El Spuddo!
My last iteration used Mundorf Supreme caps in place of the Russian paper items.
BTW The Krklec OPT referred to is no longer available. I would now recommend a 2k5 or 3k5 unit, the lower impedance seems to give a sweeter sound.
Brian.
Old 6th August 2004, 02:41 PM   #16
Brian.
Cool, even more ideas.
Thanks,
Sheldon
Old 6th August 2004, 08:41 PM   #17
powertriode is offline powertriode  England
powertriode's Avatar
How about the "Cookiebox"
http://www.mcamafia.de/tubes/keksdose/cookiebox.htm
Old 6th August 2004, 08:53 PM   #18
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
Is there a decent tube design that gives about 20-30w, and isn't too difficult for a first time tube DIYer?
Is this design any good?
http://www.lundahl.se/claus_b.html
Or for a lower powered design:
http://www.lundahl.se/claus_b_se.html
I know very little about tube amps, but want to build one to compare. The above amps were the first one I stumbled on through google.
Also, the above amplifiers use output transformers. The SE one is specified as 8w/8 ohm. Will this cause problems if my speakers are 4 ohm? The output transformer doesn't appear to have a 4 ohm tap.
Brian
Old 6th August 2004, 09:20 PM   #19
G is offline G  United States
G's Avatar
Hi Brian. Gonna try some tubes huh? You should have no problem from what I have seen of your SS amps. I have a SE EL34 that I built and I could send you the schematic. Actually it's probably on this site. The big question is do you have the sensitive speakers that are required for low power tube amps. If not you may have to do a PP amp which is a little more complex but certainly should be no problem for you to build either. Decide on the minimum power requirments for the speakers you have and go from there.
Gavin
Old 7th August 2004, 10:25 AM   #20
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
This one is also fairly simple ... 6 parts + a tube + OPT per channel plus powersupply...
http://www.t-linespeakers.org/tubes/SEP_50EH5.html
a whopping 1.4 W ... not much bass with the tiny OPTs (but someone did build the $405 version -- ie add $400 of Lundahl iron, and reported that it sounded very good).
You could get the parts count down to 4 or 5 parts if wired in triode... maybe even 3 if you lost the cathode bi-pass (but now you are down to 500 mW or so). Maybe even lose the grid stopper... now its 2 resistors per channel ... i think i'll have to try that :^)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Is there a 'Gainclone' Of the tube world?Hide this!Advertise here!
Seek for your comments/advice to newbie on Tube world afriend Tubes / Valves 6 30th August 2006 06:00 PM
Gainclone vs tube navin Chip Amps 33 21st February 2006 04:47 AM
HK & world: with Cayin, are tube kits still good value (apart from learning)? rick57 Tubes / Valves 11 10th May 2005 03:51 PM
FOR SALE World Audio Tube Amp bart_dood Swap Meet 0 17th February 2004 01:28 AM
Suggestions from the tube world rick57 Tubes / Valves 16 18th July 2003 10:27 AM
Copyright ©1999-2017 diyAudio
