Designing a LC power supply - diyAudio
Old 26th July 2004, 07:22 PM   #1
Badge is offline Badge  United States
Default Designing a LC power supply
I have a couple of Triad power transformers. I would like to design a simple solid state rectifier and LC type power supply. The transformer has two 125 volt secondary outputs with a center tap rated at 22 ma. Each transformer will be driving a 6AR8 tube at 250 volts. Idle demand for this tube is 10 ma. Could someone with suggest a circuit?
The freaks stick together, they are a tight old crew
Old 26th July 2004, 08:08 PM   #2
analog_sa's Avatar
Just get PSUDII
Old 26th July 2004, 11:04 PM   #3
Thanks I just downloaded it. My transformers are old stock. I don't have anymore data on them. How do you measure their resistance?
Old 27th July 2004, 07:56 AM   #4
SHiFTY is offline SHiFTY  New Zealand
SHiFTY's Avatar
So each transformer has two identical 125V secondaries? You could run them in series with the junction as a center tap. Or do you mean they have one secondary with a center tap?
To measure the resistance just break out the multimeter and plug the number into the program.
You have quite a few options, you could use full wave solid state or tube (classic circuit), a diode bridge (gives you higher output voltage), or a hybrid tube-diode bridge.
Old 27th July 2004, 02:48 PM   #5
ShiFtY, the tranny has three wires on the 250 volt side. Two measure 125 volts using the center wire as a ground for measuring. On detemining the resistance, do you measure across the two secondary side taps, or from primary side to secondary? Thanks.
Old 27th July 2004, 03:26 PM   #6
G is offline G  United States
G's Avatar
You will need to use a full wave bridge to get the 250 volts you are looking for. Since you are using a bridge the center tap will not enter into the equation. Measure the resistance across the entire secondary and ignore the center tap. You will then need to enter the expected voltage at the secondary (250v) and the dc resistance of the secondary into the program. After that you are ready to simulate. You said the needed current was 10mA per tube? I would assume two tubes so your load will be: 250v/.020 =12.5K. I hope that helps.
Gavin
designing SS power supply brsanko Tubes / Valves 22 1st January 2010 10:03 AM
help with designing a power supply zvir Power Supplies 1 31st March 2009 09:26 PM
Designing power supply for class D amp darw82 Power Supplies 1 3rd December 2006 07:24 AM
Designing secondary side power supply darw82 Power Supplies 10 10th August 2006 09:05 AM
Power Supply Designing using LM317, RC-snubber okina Power Supplies 4 12th September 2005 02:17 AM
Copyright 1999-2017 diyAudio
