Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Tubes / Valves All about our sweet vacuum tubes :) Threads about Musical Instrument Amps of all kinds should be in the Instruments & Amps forum |
#231 |
Here's my "How Tube Guitar Amps Work" webpage: https://robrobinette.com/How_Amps_Work.htm
And another: https://robrobinette.com/How_The_5E3_Deluxe_Works.htm |
#232 |
#233 |
Hey folks, thanks for sharing all of these links. I find myself at the beginning of my journey and these materials will help me set my first steps. I've taken the liberty of compiling all the links mentioned in this thread into a Google Docs Spreadsheet, which I'm sharing here. You will also have the possibility to comment on any cell, though not edit it directly. My next step will be to check which of these links are still valid and fill out missing fields. I hope this will help someone!
#234 |
#235 |
#236 |
Hi I am a newbie to DIY and would like info regarding mu of tubes for my LCR Phono Stage.
I would like Telefunken E8020 but to expensive so I am looking for an alternative tube. Is there a table or chart with this info that I could download? Thanks. |
#237 |
Duncan's TDSL will tell you all you need to know.
#238 |
Thanks.
#239 | |
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B |
#240 |
I have written a small guide for calculations on triode amplifier circuits.
With the help of some rules which I describe in this guide, one gets fast results when analyzing these circuits. Hope this will help. |
New To Site? | Need Help? |
