On Line Tube Learning for newbies.... - Page 18 - diyAudio
Old 16th September 2011, 11:23 AM   #171
TonyTecson's Avatar
Originally Posted by RX5 View Post
ok.. so being normal as it is, will IT(glow) not shorten the lifespan of the heater?
undervolting or overvolting is bad for any tube...a tube rated for 6.3 can work with voltages 5.9 to 6.9 volts with out problems.......
if your filament supply is higher even under full load, you can always add a resistor in series wit the the filaments to trim off excess voltage. it is a simple appplication of ohms' law...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 16th September 2011, 08:07 PM   #172
coffeedj's Avatar
Send a message via MSN to coffeedj
Default Heater Voltage
This is an interesting problem. Higher voltage increases the output/gain, but shortens life. Lower voltage does the opposite. However, we must remember that line voltages varied by up to 20% around the nation for a good part of the period of tube manufacturing--and tubes had to take this variance. Very seldom was the filter supply regulated.
I have done quite a bit of testing on varying voltages and my general recommendation is to keep power tubes at the rated voltage--this seems to give the best average performance. Small signal tubes are more forgiving, and so I like to run that at the rated value, or up to 5% under to save life. You can run them hot, but that will shorten life.
There are a few exceptions to the rule. 5687, for example, like to run hot as do 12B4s, at least with my testing of lots to date.
"Make me to know the end of my days" King David
Old 1st November 2011, 01:58 PM   #173
Default donerlank
Anyone who has built Fred Nachbauers Miniblok set? Or his Miniblok PP amp? If 13em7's are hard to come by in sunny SA, will 12ax7's work or maybe the new JJ ecc832/12dm7's? or perhaps 7025's which are listed as available here? If I understand Fred's schematic & write up correctly, the hi-gain half is used as a preamp and the low gain hi current half as the output. The miniblok 2 is a pp amp using 2 of these tubes, the 2nd tube high gain stage is used as a phase inverter for pp. The project appeals to me to cut my teeth with a kit, or can anyone recommend a better set project. It needs to be simple. I'm a blockhead at this stage.
Old 2nd November 2011, 10:34 AM   #174
nthere is offline nthere  Turkey
Originally Posted by BHD View Post
This is a great idea for a thread.
This is one of the best beginner sites I've found, it walks you step by step through the design and construction of a simple single ended amp:
http://boozhoundlabs.com/howto/
I am afraid that this site is not reachabe now. I have seen it 3 days ago and it was a good site for beginners.
Old 2nd November 2011, 11:39 AM   #175
just another
wintermute's Avatar
That's what the wayback machine is for Boozhound Laboratories
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 2nd November 2011, 11:54 AM   #176
Thank you nthere, tried boozhound in spite of what you said (just in case) always being hopeful, I have visited Hans Niejbaum's 6C33C OTL site as well as Tom Mellow's OTL site. OTL is the way I will eventually go, as Philips OTL's were marketed under the Novosonic brand in my teenage days.Ist encounter with Hi-Fi, still mono in those days, stereo came a bit later. Novosonic's had a kick like a proverbial Mississippi mule. Could feel drums against your chest if u were listening to a percussion band. Handled classical music equally well; a pity this avenue of sound reproduction wasn't followed thru, though some were more in love the the lush, mellow Dynaco sound. Sound of transformer windings? Vere nice though. But otl's aside for the moment, I need to familiarise myself with an easy inexpensive project that works. Then...OTL's. Yum, Yum. I understand the principle of the late Fred Nachbauers topology very well, I am just not sure I can substite the 13em7's with other tubes (i.e dissimilar dual trodes) but I'll get there. Don
Old 3rd November 2011, 09:27 AM   #177
just another
wintermute's Avatar
I perhaps should have mentioned that you need to wait for about 10 seconds for the boozhound page to load when you click on the wayback machine link I posted above
Tony.
Some of my photos
Old 4th November 2011, 09:57 AM   #178
Smile donerlank
Thanks,Wintermute, successfully accessed Boozehound and perhaps you will be pleased to know that the lights have started flickering for me. Isnt knowledge wonderful? Knowledge gives power, power gives enablement, enablement brings satisfaction. Dunno who said that. Perhaps it was Confucious, could even be Julius Ceasar or Shakespeare, does it matter?, or better still:Mr Tube. I will now be able to choose a tube, do some maths to determine if it will work in a given circuit, even modify the circuit to suit the tube and later on design my own circuit. I must remember to thank Boozhound also.
Old 14th November 2011, 03:53 AM   #179
Effusive thanks to all of the posters and their references
Wonderful dissemination of knowlege
Vbr,
Sam
Old 14th November 2011, 08:08 AM   #180
TonyTecson's Avatar
i can buy it back from you if you can bring it to the house....
you can buy JJ 12ax7 tubes here: http://www.epektos.com/catalog/90270...03444af81.aspx
Copyright 1999-2017 diyAudio
