New DHT heater
I'm thinking of using 4P1L tubes for the drivers.
4P1L diff driver gain is not too much, with parafeed OPT the overall gain is about 20dB.
If you use 01A as input tube (about 17dB with Ale's gyrator), the gain is -about- 70, so you need some attenuating.
I started out with three stages, but with my Mark Audio Alpair 10s in a smallish room I found that PSE 4P1Ls are just enough as outputs, so ended up with 2 stages, first being the 01A Gen 2. I feed them with a ES9023 DAC and it needs all the output that gives - around 2v probably. Nice to manage with 2 stages if you can, and in my case all filament bias. I use twin 4P1L outputs, but three is possible or you can go PP and double up. Wise to wire the 4P1L filaments in series here, so less heat generated in the cathode resistors.
Intersting schematic...may I ask why you have introduced two 100ohm resistors between the ccs and the cathodes ? I have build as well a diff pair 4p1l-preamp, but connected the ccs straight to the cathodes...so try to learn from you...
Hello,
Rod just told me my 2 regulators for my 5687 line preamp have been send.
Right now i am using LM350 with Lundahl LL1694 choke input.
For the pair of regulators, each supplying 6,3 volt 0,9A to one 5687 i will use the same transformer ( split bobbin EI ) SBYV28-100-E3 diodes. The LL1694 will be wired for 40 mH so i will need around 300mA through a bleeder resistor just to be sure.
Morgan Jones did publish on Linear Audio about snubbers across diodes. In ther end he concluded that 1nF with 1Kohm in series across the secondairy will work perfect in most cases. 1nF should be something like silver mica or just any cap what the resistor power rating, kind of resistor?
Kind greetings, Eduard
Hello Rod,
I will see what i have in stock. I do have some self healing Rifa caps but it appears the new ones are more reliable.
Being on the sec side they also have to be self healing. Even with choke input AC voltage will be below 20 volts.
For the sensing resistor i need 1,1 ohm because 5687 draws 0,9 A.
Will it need readjustment too after installing a new tube after all it is not a DHT?
Greetings, Eduard
Hello Rod and the others,
I hope the regulators will be delivered today.
The sensing resistor in my set up need to be 1,1 ohm. I have some 2,2 ohm to put in parallel. Do they need to be soldered at both sides of the circuit if not i can use use some cheap wirewounds untill Mills mra 12 will arrive. And installing will be a peace of cake
greetings, Eduard
Hello,
Got the Mundorf 22000µF caps plus the bleeder resistor ( necessary because of choke input) from the UK today. Your parcel posted one day before will hopefully arrive tomorrow.
In the past i did install 12 watt Mills where used to be a 2 watt in a pre amp. It was a BIG difference. Probably the difference between the supplied ones and the Mills in the R1 position will not be that big. Did find 1,1 ohm 10 watt Mills in the USA closer so far i could only find 2,2 ohm 12 watt to mount in parallel.
The circuit now is very basic LM350. Which got a choke input added a year ago.
Maybe your circuit is less inflenced by adding choke input but i will do it from the start!
Greetings, Eduard
p.s if anyone knows a supplier of mra 10 or 12 1,1 ohm please let me know
