#121 |
Add another pair if you can please....!
#122 |
Depending on price I would take 4 or more.
Chris |
#123 |
and another 2 please
Au rutti wop-bop-a-loom-bop-a-boom-bam-boom - Richard Penniman |
#124 |
Hi Rod;
since it is a thingy for a tube gear you may easily use IRF parts biasing them from B+. Just an advice, for flexibility.
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative. |
#125 |
Hi Rod
I am interested in at least a couple. Thanks JimS |
#126 |
#127 |
#128 |
работник
Hi Anatolij, I thought a lot about FET solutions, but in this circuit, we try to run Vds very low (1.5 .. 2V) to keep the heatsinks cool. The devices work OK, but the capacitance is huge (400pF++ even at little IRF510 level) at low Vds, and changes very rapidly with Vds change (supply ripple).
For best quality DHT heaters, we are trying to make the (ac, small-signal) impedance as large as possible, to keep cathode current from leaking out of the circuit - and from one end of filament to the other. This leakage has a very bad effect on the sound quality, and is one reason that ordinary dc heating made with voltage regulation sounds bad. In fact voltage-controlled dc sounds even worse than ac-heat - no lustre, no sparkle. With voltage regulation, the big capacitor across voltage regulator output (even if 0.1uF) presents direct ac-short-circuit across the filament, and is enough to ruin the quality of DHT-sound. Anyway, I think you're teasing me about having B+ present before heater can switch ON!!
#129 |
работник
Good to see the interest in the new board - Thank You!
I'll order as many PCBs as I dare, to keep the cost low! |
#130 |
Please add my name for 4 boards
B.Ravi |
| how to wire 6.3VDC heater on a heater with center tap (12.6V series, 6.3V parallel)? | jarthel | Tubes / Valves | 9 | 14th April 2012 05:36 PM |
