New DHT heater
New DHT heater
Old 11th September 2017, 10:46 AM   #871
eduard is offline eduard  Netherlands
Send a message via Yahoo to eduard
Hello,
Tubes not connected yet.
Overkill surely but if it can improve for a few euros it will be beneficial.
5687 will be improved a little not as much as a what for sure.
But changing into choke input for th lm350 was also a big improvement.
We will see .
Of course everybody here should switch to high efficiency drivers.
Greetings,
p.s Dht with mediocre speakers will still sound mediocre
Old 24th September 2017, 04:51 PM   #872
Hello,
Not sure yet But it seems switching to choke-put with the lm350 regulator was a bigger difference than switching from the lm350 to the coleman both with choke input.
I understand with a DHT changing in the heater supply will give bigger difference.
BUT the Coleman is cheap compared to a more regular heater supply.
Greetings, Eduard
Old 24th September 2017, 08:48 PM   #873
Rod Coleman is offline Rod Coleman  United Kingdom
работник
Rod Coleman's Avatar
New DHT heater
Changing from Cap-input to choke-input can reduce the noise coupling from this dc supply to other (more sensitive) parts of your system, like the DACs, or MC preamp stage - and that could give a better overall sound.
as Andy says, you're now in a good position to compare the range of useful DHTs for preamp duty - 4P1L is certainly a good start, and there's plenty of build guidance over at the 4P1L preamp thread.
Old 25th September 2017, 02:20 AM   #874
Truetone is offline Truetone  Australia
I am using a raw supply (845 Coleman reg) that consists of a 5A LT338 regulator board from Audiowinds 5AMP 1.5-32V Adjustable Voltage Regulator Module, LM338 | eBay
I put 100 Ohm across it to give a resistive load. It works fine but have thought about building a choke input passive supply. Any thoughts? Do I get the full benefit of the Coleman board this way? I was using the board to directly supply the filaments before.
I built a choke input supply for 4P1L Coleman boards on my filament bias preamp.
Old 25th September 2017, 03:43 AM   #875
One good thing about using a regulated raw supply is you can set the voltage for minimum and unvarying dissipation at the coleman board. I find this set up to stay cool, but it's not summer here yet! An easy way to mount the board to the chassis is to cut a small square section of aluminium and drill / tap one end and side.
Old 25th September 2017, 04:39 AM   #876
hello,
You will need a big choke like the Lundahl ll2733 with two coils in parallel to withstand the high current needed for the 845 and you will need another transformer for sure.
And i would install a bleeder resistor to take care of the minimum current needed to make it work as a choke input.
greetings, erduard
Old 3rd October 2017, 08:20 AM   #877
Any advice rgds the delay period for filament heating on 845? Does it damage the cathode if the B+ comes on first? eg as with a DH rectifier tube. I have always used a pre-heat sequence but no longer practical (for other reasons). Given that the high initial voltage is within components spec. Thanks.
New DHT heaterHide this!Advertise here!
how to wire 6.3VDC heater on a heater with center tap (12.6V series, 6.3V parallel)? jarthel Tubes / Valves 9 14th April 2012 05:36 PM
