New DHT heater
New DHT heater
Old 14th September 2012, 04:53 PM   #531
vitalstates is offline vitalstates  United Kingdom
vitalstates's Avatar
I thought I'd piggy back this thread to say thanks to Rod for the heater supplies. They work a treat. I havn't been able to comment on the sound yet as the 2 x 0-9v transformer I had in the bit box sounds like a pneumatic drill so I'm in the process of swapping it out for a toroid. It's difficult to appraise the silence with all that buzzing.
Anyway with all the talk of delayed HT I thought I'd mention this anyway:
Vitalstates - SV572
Ed
There is nowhere you can be that isn't where you're meant to be
www.vitalstates.org
Old 24th September 2012, 08:02 PM   #532
yagoolar is offline yagoolar  Poland
yagoolar's Avatar
Send a message via ICQ to yagoolar New DHT heater
Assuming I use 2 Rod Coleman's regulators for 2 DHT output triodes. Do I need
a) separate xformer windings + rectifier bridges + some C filters for each triode or
b) one winding and separate rectifier bridges + C filters for each triode?
I am afraid that in case b) there will be crosstalk between cathodes. Am I right?
Old 25th September 2012, 05:41 AM   #533
Rod Coleman is offline Rod Coleman  United Kingdom
работник
Rod Coleman's Avatar
New DHT heater
Hi, Yes, There is a risk of crosstalk, you are right. Please use separate transformer winding and rectifiers for each DHT.
For the best possible solution, a separate transformer is recommended - if the transformer is shared, cross-coupling of rectifier current pulses can increase the overall noise.
Old 25th September 2012, 05:56 AM   #534
работник
New DHT heater
Vitalstates - SV572
Ed
Hi Ed, Thank you for your kind comments!
when searching for a Filament transformer, please be careful with the quality and construction. There is a big variation of leakage capacitance between primary and secondary windings, and we need the lowest possible value here, to prevent (usually common-mode) noise entry.
Toroidal trafos are not the best performers, sad to say. The capacitance of these may be as high as 1nF, and often the core can't be grounded.
Dual-bobbin [aka split-bobbin] EI types are much better, and I measure 30 to 50pF using Industrial Control-Panel transformers from the UK supplier JMS
1 PH Trans
Most countries have a local maker of industrial trafos, and their customers also like split-bobbin construction, because of better isolation (breakdown) quality. In Italia, the equivalent company is Ideomat Italia Srl, at Modena. I am sure that there are many others.
The other reliable supply of dual-bobbin EI is from Hammond: the 266 series.
Hammond Mfg. - Power Transformer - Dual Primary / Dual Secondary (266 Series)
Regardless of the heating method (or Regulator), the transformer is important quality for filament heating, please choose carefully!
Old 25th September 2012, 07:09 AM   #535
yagoolar's Avatar
Thanks Rod. As I have little room for next xftmr, I will use existing 2 separate 6.3V (*230/220) 3A windings and voltage doublers instead of rectifier bridges.
Old 25th September 2012, 07:31 AM   #536
работник
New DHT heater
A doubler should give good results!
The attached PSUD file uses 6,3V 3A trafo to generate 11V - enough for 6B4G. The rms current in the trafo secondary is 3A.
With a 6,3Vrms 4A trafo, we can generate 10,5V dc using a similar circuit, and feed a 300B regulator.
File Type: zip Doubler_6V3rms3A_6B4G.zip (326 Bytes, 64 views)
Old 25th September 2012, 07:46 AM   #537
Vincent77 is offline Vincent77  Europe
Vincent77's Avatar
What about toroidal trafos with a grounded electrostatic shield between the primary and the secondary?
Old 25th September 2012, 07:49 AM   #538
работник
New DHT heater
These high quality trafos should work very well - they are designed to tackle the weakness of the standard consumer-quality toroidal: with the cheap toroids, the common-mode noise is very bad.
The measurement that really matters: effective capacitance from primary to secondary.
Old 25th September 2012, 08:05 AM   #539
Vincent77's Avatar
Glad to hear that. I have just ordered custom, electrostatic shielded toroids for my GM70 project... I'll measure the capacitance when I get them.
Old 25th September 2012, 08:44 AM   #540
yagoolar's Avatar
Glad to hear that!
Actually it is 6,58Vrms, as it was built for 220V primary. Now in PL mains voltage is 230V, thus 6,3V*1,045
New DHT heaterHide this!Advertise here!
how to wire 6.3VDC heater on a heater with center tap (12.6V series, 6.3V parallel)? jarthel Tubes / Valves 9 14th April 2012 05:36 PM
Copyright ©1999-2017 diyAudio
