How do you double the voltage on a PSU?
Old 21st July 2004, 12:16 AM   #1
Jonathan Bright is offline Jonathan Bright  Australia
Default How do you double the voltage on a PSU?
I happen to have two mains transformers that I got for next to nothing. The secondaries are a nominal 135 volt at over 100 milliamps. There are multi tap primaries. I have heard of voltage doublers and I'd be grateful if some one could explain how I can do that to these secondaries as they would then form the basis of a good twin mono pre-amp supply. I figure I should be able to get 135x2=270 volts plus some extra with the appropriate primary tap. I am aware that the ripple voltage will be the same as the mains supply but after that I'm not sure. Can someone put up an illustration please, preferably with capacitor values/ratings etc?
"It was the Springtime of the year when aunt is calling to aunt like mastodons bellowing across primeval swamps." P.G. Wodehouse.
Old 21st July 2004, 12:48 AM   #2
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
A voltage doubler rectifier into a capacitive load would give you roughly twice the primary voltage at half the primary current.
Ripple voltages are much higher due to less adequate filtering so care needs to be taken to further filter it prior to feeding the B+ to the circuit.
GLASSWARE
Frank
Old 21st July 2004, 01:18 AM   #3
PassFan is offline PassFan  United States
Pay close attention to the first half of Franks answer. The VA rating of your transformer will not change. At twice the voltage you get half the current. Maybe it will still work for you , maybe not.
Old 21st July 2004, 06:23 AM   #4
ray_moth is offline ray_moth  Indonesia
diyAudio Moderator Emeritus
ray_moth's Avatar
A voltage doubler works by connecting a pair of diodes in opposing polarity to one end of the secondary winding, so as to maintain charge on a pair of capacitors, one negatively and the other positively, with respect to the other end of the secondary winding. The following rough schematic gives the idea.
Xfmr diode
||C--------------|>|------------- +270v
||C | |
||C 135v | = capacitor 220uF
||C | |
||C------------------------
| = capacitor 220uF
-----|<|------------ 0v
diode
It relies on each capacitor retaining its charge long enough so that its voltage doesn't drop significantly between charging pulses, which occur one each mains cycle (i.e. 50 positive and 50 negative pulses per second). The values of 220uF shown in this example should be more than adequate for your purposes.
All this energy has to come from somewhere, consequently what you gain in volts you lose in amps. Your 135v 100mA transformer will be able to provide ~270v but at only 50mA max. However, for most preamps I've seen this should be enough.
The voltage doubler produces 50htz ripple and should be followed by a good filter.
Old 21st July 2004, 06:32 AM   #5
ray_moth's Avatar
Sorry about that bl**dy mess! I spaced it all out properly but the typing collapsed when I submitted it. Basically:
1. Connect one end of the transformer secondary to the junction of a pair of electrolytic capacitors diodes in series.
2. Connect the other end of the secondary to the junction of a pair of diodes in series.
3. Connect the other ends of the diodes to the other ends of the electrolytics, observing correct polarity.
4. Take the output of the voltage doubler from the ends of the electrolytics.
Old 21st July 2004, 06:41 AM   #6
Thanks all. Yes I'm up to speed on VA ratings. Frank, I take it that what you have refered to as the "primary" is what I assume is the secondary (of the transformer) IE the primary is the mains side and the secondary is the winding prior to the rectifier. Any way I think I'm clear now. Ray moth your written explanation will make sense of a diagram I have. Thanks.
Old 21st July 2004, 06:45 AM   #7
tubetvr is offline tubetvr
There are several ways to make voltage doublers. On this page http://www.du.edu/~etuttle/electron/elect9.htm some of the most common are shown, full wave, half wave and multiplier type. The fullwave type gives much lower ripple as the ripple frequency is 100Hz but the disadvantage is that both inputs are floating but it doesn't matter so much with transformer coupling.
There are another variant using a bridge rectifier which seems to be less popular but it has an advantage if you want to make a circuit that i easily switched between ordinary rectification and voltage doubling, one example is here http://sound.westhost.com/project65.htm
Regards Hans
Old 21st July 2004, 06:56 AM   #8
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Originally posted by ray_moth
Code:
Xfmr                diode
 ||C            |                 |
 ||C            |                 |
                  |                 = capacitor 220uF
                        diode
Let's see if the CODE tag helps. If not, hit QUOTE on this or his post to see how it was typed.
The hum output from such a doubler is 120Hz. It's a FULL WAVE doubler. One ''up" pulse to the top cap followed by a "down" pulse to the bottom cap, due to the connection the phases are equal and they both go up.
Does your transformer have a center tap? Have you been using it FWCT? (Typically for tubes; one diode on each 'arm' of the winding, pointing towards the first filter cap, which is grounded to the CT.) If so, just put a FWB (SS or if you want to be annoying, damper diodes) on it and go. Double voltage, half current.
Which reminds me, multipliers are tough on transformers so you'd be wise to derate the current draw a bit. Although, the winding is used in the same way so I suppose it wouldn't be too much worse than the standard RMS 1.5-2x derating used with FWCT or FWB rectifiers.
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 21st July 2004, 06:58 AM   #9
Yvesm is offline Yvesm  France
Yvesm's Avatar
Just a little drawing could help
Old 21st July 2004, 07:51 AM   #10
Appreciate the links and clearer diagram. Thanks. JB
How do you double the voltage on a PSU?Hide this!Advertise here!
useing 2 regulators for double voltage...is it possible?? Minion Power Supplies 10 13th September 2007 04:12 AM
double-TL useful? el`Ol Full Range 8 19th December 2005 12:04 PM
Double rail PSU, double ground rail connexion ? youyoung21147 Chip Amps 5 6th November 2005 05:12 PM
about double tl~ bigcatdairy Multi-Way 0 29th September 2005 02:51 PM
Rail voltage compared to transformer voltage SteveG Solid State 4 22nd July 2002 11:50 PM
Copyright ©1999-2017 diyAudio
