i currently bought a pair of the ATH-W1000's headphones
Features Successor to Audio-Technica's popular ATH-W100 wooden headphones D.A.D.S. (Double Air Danping System) for deep bass extension and reproduction Super high class 8n-OFC with bobbin winding voice coil designed to project sounds in detailed delicacy Perm-alloy magnetic circuit adoption Titanium flange phi 53mm driver adoption. Audio-Technica's unique Wing Support Housing vibration-proof mechanism (PAT) gives comfortable support for a better listening experience High durability artificial leather eadpads Wrapping 3.0m 6N-OFC+Hi-OFC hybrid input cord Wooden sleeve matches headphones in perfect unison Specifications Type: Closed Dynamic Driver Unit: 53mm, Super high class 8n-OFC Bobbin winding voice coil Magnet: Neodymium Frequency response: 5-40,000 Hz Impedence: 40Ù Max. Input Power: 2,000mW Sensitivity: 100dB Plug: Gold-plating phi 6.3 stereo standards Cord length: 3.0m (Wrapping / 6N-OFC + Hi-OFC hybrid) Net weight (without cord): 350g i am new to headphone amplifiers in general and i need to know a good portable and home amplifier for this pair of headphones if you could help me that would be awesome. cheers. note i am only using this for personal use i dont need any 4channel + amp. |
#2 |
That 40 Ohm impedance can be a source of GRIEF if tubed circuitry is used. I have the same issue with my Grado SR225s. I use a Sheldon Stokes SS headphone amp that I think is excellent. Like Dr. Stokes says, it does not sound like SS.
Sheldon Stokes' web site: www.quadesl.com
Eli D. |
#3 | |
www.head-fi.org. Look for Kevin Gilmore's Dynahi and Migmini amps. www.headwize.com err edit maybe not the SS Dynahi. |
#4 | |
Will the Musical Fidelity X-CAN v3 have problem driving it?
| Amplifier for headphones | Sponkii | Chip Amps | 52 | 20th January 2009 06:07 PM |
| amplifier for electrostatic headphones | silke.wein | Solid State | 3 | 6th November 2004 01:07 AM |
| ATH-W1000 headphones need amplifier | ATH-W1000 | Pass Labs | 1 | 20th July 2004 08:02 PM |
| ath-w1000 headphone need amplifier | ATH-W1000 | Headphone Systems | 1 | 20th July 2004 02:13 PM |
| Simple Headphones Amplifier | Chrisv1983 | Solid State | 7 | 22nd June 2004 10:02 AM |
