Old 18th July 2004, 03:26 PM   #1
sparkle's Avatar
Default g. pimm's rev3. and rev. 4 -6P1P/5687 ???
Hi!
I am considering using mr. Pimm's ccs rev. 3 or rev.4 in my line preamplifier. I have 4 pieces of 6P1P russian penthode at home that I can use. Can someone tell me the spec's for that tube- screen voltage/current, plate voltage.... I need two working points to try the tube/ccs - on 15mA and on 20mA. I would like to use it with 5687 as lower tube.
thanks in advance
daniel
Old 20th July 2004, 04:47 AM   #2
sparkle's Avatar
Old 20th July 2004, 10:22 AM   #3
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
It is a 6CM6 with a different pinout, pretty much.
AKA 6V6 in 9pin mini registration. Just use 6V6 specs, for the most part...
pinout
ratings, curves, etc
not sure how much it will help if your russian isn't up to snuff
Old 20th July 2004, 10:56 AM   #4
sparkle's Avatar
Thanks- that is what I was looking for....
best regards
daniel
dantimax rev3 help Bengali Everything Else 2 9th October 2008 09:47 PM
is Gary Pimm still around? Nanook Tubes / Valves 9 17th June 2007 09:15 PM
5687 dc 5687 tube amp need help vangogh-hk Tubes / Valves 8 4th January 2006 12:09 AM
Questions on Brian's PCB PS (rev3.0) ?? methar Chip Amps 0 23rd May 2005 07:41 AM
mr. pimm's ccs rev.3? sparkle Tubes / Valves 9 25th August 2004 06:40 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
