diyAudio Sponsor
Old 17th July 2004, 02:05 PM   #1
karma is offline karma  Canada
karma's Avatar
Arrow 32 NOS RCA 1644 (12L6-GT) Twin Pentode tubes
i got these tubes cheap on e-bay. anyone ever maid a amp with em?
what would you use em for
Old 17th July 2004, 02:46 PM   #2
Frank Berry's Avatar
The RCA 1644 tube is a 12L8. Not a 12L6. The two sections share a common cathode.
They were probably designed to be used in the output stage of radio receivers.
Frank
Old 17th July 2004, 04:11 PM   #3
karma's Avatar
thanks frank ill just add em to the rest of em. maybe down the road i can use em.
only cost me $11
Old 17th July 2004, 07:46 PM   #4
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
yeah, it's a 12L8.
shared cathode and screen, so ideal for PP.
but, unfortunately it is rated only 2,5w Pa, each section.. so flea power, unless you use your whole set in PPP
Old 31st July 2004, 01:06 AM   #5
karma's Avatar
where can i find a pdf of the pinout of this tube?
thanks.........
Old 31st July 2004, 01:54 AM   #6
rdf is offline rdf  Canada
rdf's Avatar
thanks.........
Not a .pdf, but some info:
http://hereford.ampr.org/cgi-bin/tube?tube=1644
Old 31st July 2004, 01:59 AM   #7
diyAudio Senior Member
fdegrove's Avatar
........The datasheet for the 12L8 in PDF format.
DUNCAN AMPS
Frank
Old 31st July 2004, 02:54 AM   #8
karma's Avatar
ahh thanks heh only 180 max volts on the plate hmm.
wonder if i could make a headphone amp with a few
nah not now i still gota finished my other tube amp first
thanks.........
Old 12th September 2009, 11:30 AM   #9
Shoog's Avatar
Hi all,
Just searched up this thread.
I have been toying with the idea of building a two stage direct coupled 6080 amp for ages now. The idea is to hang the pentode driver off the finals and direct couple a LTP into a differential PP output.
I have been searching for a suitable driver which would allow me to build this as a two valve per channel design. I was toying with compactrons, but they are a pain because they never caught on in Europe and so the bases and valves are hard to come by. So I was almost going to give up when I did a painstaking search of the valve lists and came up with the 12L8-GT. Seems that this is almost perfect for the job and the curves don't look to bad.
So my question is, has anyone ever used them for anything, and if so how do they sound. Also has anyone got a source for them in Europe?
Shoog
question about twin triode tubes Nihilist Tubes / Valves 2 19th February 2009 05:39 AM
Twin RS 15 HF Sub elambert Subwoofers 0 31st August 2006 11:36 PM
6L6, 12L6 not same tube! rcavictim Tubes / Valves 9 11th April 2006 05:16 AM
A small no-fuss pentode/pentode SE amp Tubes4e4 Tubes / Valves 13 1st January 2006 06:16 AM
What can I do with 3Q4 Pentode tubes? abmoggy Tubes / Valves 2 3rd May 2005 10:32 AM
Page generated in 0.10096 seconds (83.87% PHP - 16.13% MySQL) with 11 queries
