5687 Preamp as I plan to build it. - diyAudio
Old 15th July 2004, 11:52 PM   #1
G is offline G  United States
G's Avatar
Default 5687 Preamp as I plan to build it.
Hi All,
Here is the 5687 preamp as I plan to build it. Simple and to the point. I'm going to brave the hazards of AC filament voltage on this project. Hopefully my layout and grounding scheme will be up to the task. I decided on the 5y3 because of the minimal current demand. Any suggestions are welcome.
Gavin
Old 15th July 2004, 11:54 PM   #2
G's Avatar
Here is the PSU:
Gavin
Old 18th July 2004, 12:20 PM   #3
Gavin
When I built my 5687 I used a VR regulated supply and it sounded better with it than without. I also used 30H chokes in the power supply and DC on the filaments.
It is a nice sounding line stage but somewhat pale when up against a 12B4 line stage.
Joe
Old 19th July 2004, 03:47 AM   #4
G's Avatar
Hey Fingers. Did you use a tube regulated supply or a SS regulated supply? Can you post a diagram? I'm actually considering using a shunt regulated supply with OD3s. Aren't you proud Frank and SY?
Gavin
Old 19th July 2004, 03:58 AM   #5
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Gee, seems like a waste of a 5Y3 to me. :P (20H chokes too, but I digress.) A 6X5 would work, you might be able to find a stylish model, Idunno...
Properly handled, you'll find AC heaters work very nice indeed.
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 19th July 2004, 04:31 AM   #6
G's Avatar
Originally posted by burnedfingers
Gavin
Joe
I suppose I will have to avoid listening to 12B4A linestages.
Gavin
Old 19th July 2004, 04:42 AM   #7
Quote: Properly handled, you'll find AC heaters work very nice indeed.
Gee, I suppose a VR regulated supply and rectifier tube would be a waste also.
Old 19th July 2004, 05:37 AM   #8
Sch3mat1c's Avatar
Well, as a coincidence the two amps I use (Frankenhouse and Hept'AU7) both have rectifiers, but they just happen to have more power and sound most similar than anything else I have. I'm a lazy builder
You can reg if you want but it won't affect anything as far as I'm concerned.
Tim
Old 19th July 2004, 05:38 AM   #9
Sch3mat1c's Avatar
I see nothing wrong with the 12B4. I haven't done anything besides a really abusive circuit but it looks great. Maybe I'll build a PPP or PSE amp some day with 'em...
Tim
Old 19th July 2004, 06:00 AM   #10
DougL is offline DougL  United States
I was curious about your design, so I broke out the sim tools.
Chose 29 Ma as the bias current. Got that from a tube cad simulation of the circuit. The circuit sim looked good.
I ran a simulation on Duncan amp tools.
It looked to me that the supply had some ringing.
You may want to re-visit your design.
This may or may not be an issue in the real circuit.
Just thought you would want to know.
Cheers;
Doug
5687 preamp transformer losacco Tubes / Valves 2 1st May 2009 01:21 AM
DIY 5687 Preamp BillyF Tubes / Valves 17 14th February 2007 08:13 PM
Distorting 5687 preamp circuit dsavitsk Tubes / Valves 13 14th June 2006 03:31 AM
a simple preamp with 5687 tubes karma Tubes / Valves 3 23rd April 2003 09:44 PM
Copyright 1999-2017 diyAudio
