Old 21st July 2004, 05:45 AM   #11
Antonio Tucci's Avatar
I think that the design by Bob Hoekstra represents one of the most (probably the most) interesting SE design developed in the last years.
My question regard it is the following: Is it possible realize a similar circuit utilizing only two stages (...EC99-300B) ?
Old 21st July 2004, 03:33 PM   #12
serengetiplains's Avatar
Hoekstra's direct coupling design can be configured, with a small loss of elegance, for two stages. One need only adjust values to properly bias the tubes, including adding bias circuitry for the ECC99/6L6. To gain a different perspective on this design, you might glance at the following, which is a circuit essentially the same as Hoekstra's except it uses resistor anode loading:
http://www.valvediy.com/simplexpg1.html
A two-stage design would retain the benefits of direct coupling between driver and output, and driver power supply noise cancellation through that coupling method.
ArnoldC's IT coupled 300B amplifier arnoldc Tubes / Valves 59 12th November 2007 10:57 PM
417A-300B Plate Choke or Interstage Coupled? sgerus Tubes / Valves 21 14th January 2007 12:45 AM
An intriguing 300B SE-direct-coupled-amplifier Antonio Tucci Tubes / Valves 27 8th February 2006 09:34 AM
An intriguing 6S45P direct coupled 300B amplifier Antonio Tucci Tubes / Valves 27 22nd October 2004 11:06 AM
Can someone explain parafeed & direct coupled & a.c. coupled? mwmitchell Tubes / Valves 2 11th September 2002 01:10 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
