How do you properly ground a Tamura OPT?
Old 13th July 2004, 06:03 AM   #1
arnoldc is offline arnoldc  Philippines
Send a message via Yahoo to arnoldc
Default How do you properly ground a Tamura OPT?
i have been using the Tamura F-475 for some months now but the secondary (to the speaker) is floating.
the F-475 has pins for "E" and "G" and i suppose they're for earth and ground, respectively?
so do you connect the "E" to the chassis and "G" to the signal ground (via the input RCA ground)?
my MagneQuest DS-025's common is connected to the input RCA ground, which i suppose is the right thing to do. please correct this if i'm wrong.
cheers.
Old 13th July 2004, 04:43 PM   #2
commstech is offline commstech  Indonesia
u are not wrong
Old 15th July 2004, 01:43 AM   #3
hey thanks! is your comment for the tamura, magnequest or both?
How do you properly ground a Tamura OPT?Hide this!Advertise here!
Tamura HM-1 fxsound Tubes / Valves 2 20th July 2009 08:42 AM
how to ground properly? Denis.BR Chip Amps 4 27th March 2007 08:17 PM
Tamura F-475 in Parafeed? arnoldc Tubes / Valves 2 17th August 2005 01:07 AM
tamura opt need help robertc Tubes / Valves 11 9th January 2005 05:12 PM
does connecting mains ground with circuit ground create a ground loop? jarthel Everything Else 0 25th June 2003 01:55 PM
Copyright ©1999-2017 diyAudio
