Old 11th July 2004, 08:05 PM   #1
FASTBACK's Avatar
Default Where can I use this tubes
I have the following tubes but I really don't know where to use this.
Here is the list, any inputs would be greatly appreciated.
13GF7
29KQ6/PL521
17DW4A
IBY2
31JS6C
I6A8
30AE37/PY88
6GH8
6CG8A
33GY7A
9JW8
5CG8
6FS5
4EH7
9R-AL1
6BD11
6DE4
17JZ8A
6FG7
8X9/PCF200
6JN6
3GK5
35W4/HY90
PL84 15CW5
3DT6
2GK5
5U8
10JY8
6X8A
4HA7
6ARII
6BD11
6JZ8
7A8
6SL7
12V6GT
Old 11th July 2004, 08:51 PM   #2
G is offline G  United States
G's Avatar
the 12V6GT and the 6SL7 can be used to make a nice little single ended amp but I'm not familiar with the rest of them. Surely Eli, Frank or SY ( not necessarily in that order ) can help you with some of the other ones.
Gavin
Old 11th July 2004, 09:11 PM   #3
FASTBACK's Avatar
Gavin
Thanks for your reply. That would be a good starting point for a next project of mine.
Hope to make use of those tubes for audio projects in the near future.
Old 11th July 2004, 09:41 PM   #4
G's Avatar
You are most welcome. Good luck in your project. Let us know here at the forum if you need any help.
Gavin
Old 11th July 2004, 09:41 PM   #5
diyAudio Senior Member
fdegrove's Avatar
Unless you really want to put them to use in audio applications most of the tubes on the list are either for TV use or were used in older radio sets and such.
The easiest way to go about it IMO is to run them through Duncan Munro's database program:
TDSL
Some of them can be used indirectly:
For instance the 13GF7 can be used in a series regulator, 5U8 is a rectifier, PL84 is the 15V heater version of the EL86/6CW5, etc, etc.
If you should have questions about the usabilty of a particular type for audio, just ask.
Frank
Old 11th July 2004, 10:00 PM   #6
FASTBACK's Avatar
TDSL
Franks
I'll install the Tube data sheet locator and will try to check its specification.
Can you recommend a good site for studying vacuum tubes?
Thank you very much.
Old 11th July 2004, 10:10 PM   #7
fdegrove's Avatar
Sure.
Besides books there are quite a number of sites with very useful information about the use of vacuum tubes for audio.
The best known, I think, is John Broskie's The Tubecad Journal.
TUBECAD
Another must read series of articles by Norman Crowhurst can be found here:
AUDIO CLASSROOM
The same site carries a number of books and various references for the serious builder as well.
Frank
Old 12th July 2004, 12:34 AM   #8
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Frank, 5U4 is a rectifier. 5U8 is a triode-pentode which comes in handy.
Sounds like TV tubes, the sweeps could be used for output and such triodes, pentodes or triode-pentodes can be used for preamp and driver circuitry.
Tim
Seven Transistor Labs
Projects and Resources
Old 12th July 2004, 12:50 AM   #9
fdegrove's Avatar
Quite right, like 6U8/ECF82 sometimes used as a splitter/driver...
Radford, I think.
The Russians have a rectifier that is sometimes erroneously written as 5U8. (5C8S according to TDSL).
Anyway, provided there are at least a few of the more interesting types available, some nice stuff can be built with some of the tubes on that list.
The 12V6 is definetely a good tube to work with and there should still be plenty of NOS ones around.
Frank
Old 12th July 2004, 03:24 AM   #10
Sch3mat1c's Avatar
Radford, I think.
Williams, I think.
Tim
Tube Noob! need help with tubes lots of tubes therapy_fan Tubes / Valves 15 29th January 2009 09:01 PM
WTT: Various tubes for 6CA4/EZ81 rectifier tubes GordonW Swap Meet 4 27th August 2008 12:37 AM
Tubes! Geek Swap Meet 4 16th May 2008 06:20 PM
CV428 tubes (Loktal 807) tubes FS mobyd Swap Meet 3 2nd January 2008 11:26 AM
many new tubes and tubes meter for sale elviukai Swap Meet 4 30th October 2003 09:22 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
