schematic from this amp 45/717a/5u4.. - diyAudio
Old 11th July 2004, 11:40 AM   #1
sonix is offline sonix  Germany
Question schematic from this amp 45/717a/5u4..
hi,
have anyone the schematic from this amp?
yamamoto a-08
thanks
sonix
Old 11th July 2004, 12:42 PM   #2
Previously: Kuei Yang Wang
Default Re: schematic from this amp 45/717a/5u4..
Konnichiwa,
yamamoto a-08
The Web Pages contain enough high rez photos of the innards to reverse engineer the schematic, so have a go.
Start with these, rotating them to be readable:
Then look at the picture of the circuit in thius PDF - zoom in:
http://www2.117.ne.jp/~y-s/A-08ura.pdf
Another hint, electrially the 717A and the C3m are not miles away.
Sayonara
Old 20th July 2004, 01:28 PM   #3
rafalc is offline rafalc  Hong Kong
There is full schematic in August MJ Audio
Rafal
Old 14th December 2004, 11:50 AM   #4
Konnichiwa,
I have decided to post the Schematic in another on-line group with pretty complete detail, so also find it here, in context. It is basically 99%, one or two values may be slightly different, but not much.
If you want to copy the Amplifier you do of course need the iron, considering fit/finish, component quality and inclusion of NOS Valves I'd think it's worth giving Yamamoto the business and buying the Kit if you want to build the Amplifier, a Set of Tamura Transformers and a nice case plus the valves will take most of the cost of the kit.... ;-)
Sayonara
Old 9th February 2008, 07:53 PM   #5
kmtang is offline kmtang  Canada
kmtang's Avatar
Default Lundahl LL1620 SE 30mA OPT for 45 tube
I found that even the output power of the 45 tube in SE mode is only 1.5W, it has the advantage over the 2A3 and 300B because its idle current is only 30-35mA. I built two 45 amps with LL1620 and LL1620AM which is specified to work at 30mA. According to the datasheet, the primary inductance almost 100H. Most of the SE OPT for 2A3 and 300B are with approx 24-30H primary inductance.
After listening to these two amps in about 2 months time, I noticed that its bass response is excellent.
My friend just bought the Yamamoto 45 amp. I would really like to hear it to see what are the differences between Yamamoto and mine. BTW, my 45 amps are using 6SN7 for the driver which is the design from Sun Audio's 2A3 SE amp.
Johnny
Old 12th June 2010, 07:40 AM   #6
codyzox is offline codyzox  Serbia
I need it also...Can someone post details with original shematic and parts list (also from which manufacturer are parts exactly). It would be a great help, not just for me i think...Big thanks in advance...
Old 14th June 2010, 06:40 AM   #7
Johnny
Have You compared them?
Old 14th June 2010, 08:45 AM   #8
Am I the only one here that finds this schematic not compelling?
Unbypassed zener string, Pentode driving a triode, ewwwww! Ok, the transformers and the cherry wood and the finish are sexy, but it really looks like somethinh an amateur would design. (How am I going to drive the DHT, it needs a lot of voltage! Oh! I ll just stisck a Pentode it has all this nice voltage gain!!!!)
Old 14th June 2010, 04:42 PM   #9
kevinkr's Avatar
While I understand your objections and would have completely agreed not too long ago I have to mention that I have heard several similar amps that sounded surprisingly good in fact. (IMHO I think in a lot of cases a single stage driver is preferable to several cascade triode stages in terms of resolution if there is sufficient drive capability available. Here I would probably use a single 5842/417A triode myself.) Given the voltage levels on the screen of that pentode I would be surprised if you could hear a difference in noise levels bypassed or unbypassed. You might want to try it before dissing it, once having done so you have more than engineering dogma and opinion to base it on.. (I have been all too guilty of the same things, so please don't take my comment too seriously..) FWIW
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 12th October 2011, 04:05 PM   #10
directdriver's Avatar
costis_n: "Pentode driving a triode, ewwwww!"
What's wrong with using pentode? Have you listened to it or an amp using pentode driving a triode? Didn't the Western Electric 91 use the same thing? If designed right, I don't see any reason to object to it.
Matched pairs 717A Western Electric/Tung Sol phrarod Vendor's Bazaar 2 12th April 2016 10:20 PM
NAD 304 Schematic Makofoed-6sn7 Solid State 5 3rd May 2006 06:41 AM
717a plate volts 845amp Tubes / Valves 6 30th December 2005 11:22 PM
717a Datasheet mrstone Tubes / Valves 7 5th August 2004 05:05 PM
What do you think about this schematic? PanzerLord Solid State 9 8th March 2004 06:43 PM
Copyright 1999-2017 diyAudio
