schematic from this amp 45/717a/5u4..
Old 12th October 2011, 04:08 PM   #11
kevinkr's Avatar
Originally Posted by directdriver View Post
What's wrong with using pentode? Have you listened to it or an amp using pentode driving a triode? Didn't the Western Electric 91 use the same thing? If designed right, I don't see any reason to object to it.
Depends a whole lot on the pentode used, some of the more modern high transconductance types are quite good at it, the concern is always going to be the effect of output tube miller capacitance on the HF response.. High transconductance pentodes with modestly sized plate resistors running at high currents should slew well enough at high frequencies and shouldn't have a problem to well beyond 20kHz..
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 28th July 2012, 04:15 PM   #12
maximka is offline maximka  Russian Federation
Tell those who have wills voltage characteristics 717A
Old 19th August 2013, 08:37 PM   #13
Rewind is offline Rewind  Sweden
Rewind's Avatar
Originally Posted by ThorstenL View Post
Konnichiwa,
I have decided to post the Schematic in another on-line group with pretty complete detail, so also find it here, in context. It is basically 99%, one or two values may be slightly different, but not much.
If you want to copy the Amplifier you do of course need the iron, considering fit/finish, component quality and inclusion of NOS Valves I'd think it's worth giving Yamamoto the business and buying the Kit if you want to build the Amplifier, a Set of Tamura Transformers and a nice case plus the valves will take most of the cost of the kit.... ;-)
Sayonara
Can't really afford a $2400 amp as a student. What should I look for if I want to find similar irons?
Old 19th August 2013, 08:59 PM   #14
Palustris is offline Palustris  United States
Palustris's Avatar
Check out Lundahl to see what kind of "budget" transformers they recommend.
Lundahl Transformers
Old 19th August 2013, 09:04 PM   #15
Rewind's Avatar
Lundahl - budget?
The thing is I am a noob when it comes to transformers. I see units like "CT" and I have no clue what is going on. What values should the transformers in the Yamamoto A-08 have?
Old 8th October 2015, 08:08 AM   #16
QSerraTico_Tico is offline QSerraTico_Tico  Europe
QSerraTico_Tico's Avatar
Schematic:
http://www.jacmusic.com/Yamamoto/ima...A08-Manual.jpg
Old 8th October 2015, 08:21 AM   #17
Originally Posted by codyzox View Post
I need it also...Can someone post details with original shematic and parts list (also from which manufacturer are parts exactly). It would be a great help, not just for me i think...Big thanks in advance...
Lot of info here:
★ J A C - M U S I C ★ EMISSION LABS TUBES ★ YAMAMOTO SOUNDCRAFT ★ NOS TUBES ★ You must like:
http://www.jacmusic.com/Yamamoto/htm...it-version.htm
Old 9th November 2015, 03:06 AM   #18
wyan is offline wyan
Quick question here: what is the original Tamura output transformer model used in Yamamoto A-08/s? And is there any replacement from Lundahl amorphous core lineup? Thanks.
schematic from this amp 45/717a/5u4..Hide this!Advertise here!
Matched pairs 717A Western Electric/Tung Sol phrarod Vendor's Bazaar 2 12th April 2016 10:20 PM
NAD 304 Schematic Makofoed-6sn7 Solid State 5 3rd May 2006 06:41 AM
717a plate volts 845amp Tubes / Valves 6 30th December 2005 11:22 PM
717a Datasheet mrstone Tubes / Valves 7 5th August 2004 05:05 PM
What do you think about this schematic? PanzerLord Solid State 9 8th March 2004 06:43 PM
