| diyAudio Sponsor | ||
#61 |
There is also the 6LE8 (and some smaller dual control relatives too: 6BU8, 6KF8, 6MK8, 6GS8, 6HS8) which operates somewhat similarly to a BDT, but is actually a pentode with two highly effective (fine mesh) suppressor grids and two plates. Their functional operation is almost drop-in for the BDT tubes (but different pin-out unfortunately). These often go for $0.50 to $1 when on sale. They were used for color TV demodulators. You can also make them operate as a normal pentode by putting about +12 V on g3 and tying the plates together. Should work for volume controls at least.
The BDTs and the 6LE8 should be useful for harmonic generation for say guitar amplifier effects, since they can be used to multiply signals. Square a signal and get 2nd harmonics, square it again and get 4th harmonic. Lots of 2nd H and some 4th harmonic make everything sound like guitar music. I plan to try this out for the cheap guitar amplifier thread.
Ohms Law V = I R Last edited by smoking-amp; 5th July 2011 at 10:04 PM. |
#62 | |
But also it seems that 1) reducing signal level reduces the distortion relatively even more, so this should not be bad in small signal levels. 2) However decreasing gain of the device seems to be more problematic because it increases distortion.
All distortions are not equal. By the way: I hate overuse of acronyms. |
#63 | |
http://constructions.f6fkn.com |
#64 |
I have some 7360 tubes getting dust , maybe it is time to make some experiments with them. I think they are similar to 6AR8 but with diferent pinout. I saw somewere that can be used in guitar amps to make very nice sound efects.
Silvino |
#65 | |
Now these anodes will be driving some SRPP tubes which (hum permitting) will be sitting at about 500V (250V per tube, 6N2P-EV tubes - will the swings exceed their max anode voltage ratings?), so I'll really want to hang the BDTs off about 400V, so I have the questions: How much current should each anode idle at (min volume and max volume)? I was thinking of perhaps having a switchable gain for 'quiet' and 'loud' on these - but there is risk of a switchover thump of some magnitude.. don't really want the switch sitting at 400V either so perhaps there is a way ising the grid? Also planning of using a 7809 for the 9V volume voltage - do you think that is good enough? I was thinking that if hum was a big issue with these tubes is the approach of mu-metal wraps or injecting an opposing hum (perhaps from the heater AC via a pot) - any thoughts? |
#66 |
Mu-metal screens are the usual cure for these valves. You might get away with careful positioning if signal levels are high enough.
#67 |
I don't understand the 2k anode resistors and the 250V supply rail, with the anode dissipation of 10mA total (from the datasheet).
With 2k x 5mA = 10V, so does the other 240V sit across the tube? Usually the tube would seem to have 220k anode resistors, so could someone explain the 2k ones to me? Thanks in advance! |
#68 |
Just wanted to be sure that you are on a thread about John's older design that he has refined with more that 1 revision IIRC.
Here's another thread on a newer version: John Swenson's New BDT preamp It might be worth it to google AA to see if there's something newer. If you actually have made a conscious decision to build this version that's fine, I just wanted to be sure you were aware.
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#69 |
Thanks leadbelly, I had seen that thread but was rather confused by it.
It seems to end with the construction of power supplies and power amps, which isn't what I want to do at all! Also I don't want any CCS stuff (silicon) either, I like the nice simplicity of the first diagram Plus I have limited space, I'd be tempted to put an SRPP top on the anodes but that needs two more envelopes! I guess it all depends upon getting a nice operating volume with G1 balancing the tube nicely at about 3mA, with max level at about 5mA per anode - turning down all the way to 0mA at zero level (I'm guessing at -9V at G1 is cutoff - must check the curves again!). |
#70 |
Should be able to make a parafeed phase splitter (or floating parafeed) with a BDT easily. Something like 430K and 560K from the left plate and right plate respectively over to the right deflector. Then 510K from that deflector down to opposite B- (or whatever needed) to get the deflector DC level down near ground level (or use a cap between the deflector and the above R divider, with a bias resistor from the deflector to a bias level adjust pot for the deflector). Input signal on the left deflector.
The 6ME8 will work with around +75V on the deflectors, so might be more convenient to set up. Using some Gyrators for the B+ plate loads would get the gain up around 6 instead of 2. (higher value plate loads are more linear and higher gain, the BDT is just like two common cathode triodes setting on a CCS) The resistive divider network needs to be set up to attenuate the output signal level down to 1/gain for the right deflector to get equal outputs.
Ohms Law V = I R Last edited by smoking-amp; 23rd February 2012 at 01:10 AM. |
| The JC-2 preamp schematic on the website is wrong...Mr.John C? | X.G. | Solid State | 77 | 26th September 2009 04:14 PM |
| Blu Eyes Amplifier | Tyimo | Solid State | 4 | 22nd July 2008 03:41 PM |
| John Swenson's New BDT preamp | jkeny | Tubes / Valves | 27 | 3rd June 2008 08:49 PM |
| Toshiba 3950 w/ John Swenson Mod vs. 1543 Non-Oversampled Dac | Tuber | Digital Source | 6 | 28th November 2004 01:42 PM |
| Page generated in 0.11513 seconds (82.72% PHP - 17.28% MySQL) with 11 queries |
