| diyAudio Sponsor | ||
I would like to built a small amp. I saw: http://www.t-linespeakers.org/tubes/SEP_50EH5.html and http://www.lh-electric.4t.com/projects/tiny3w.htm
is there any other amp schematic ? or mod i can do for those two amp ? |
#2 |
have you seen the 12B4A amplifier? many said it is good. i am just finding time to make one myself.
#3 | |
Gavin |
#4 | |
diyAudio Senior Member
The small VTL Tiny Triode was just that and sounded fabulous on a pair of Martin Logan CLSs if not pushed too hard. Cheers,
Frank |
#5 |
diyAudio Moderator Emeritus
My first small tube amp was a Mullard 3-3, which uses EF86, EL84 and EZ80. A kit for this amp is advertised at: Mullard 3-3 together with a description.
I liked the sound of this little amp. The scehmatic is as follows: |
#6 |
http://digilander.libero.it/paeng/a_...e_Tube_Amp.htm
The 6c45 makes a nice little amp, You can use the Hammond 125ESE for the output. This will get you 1.5 watts of exceptional sound. Joe Esmilla (JE LABS) really likes them and they are not very expensive. http://members.myactv.net/~je2a3/125ESE.htm |
#7 |
| The Tiny Pre Amp | uhcmos | Swap Meet | 13 | 8th August 2008 11:16 PM |
| Tiny, tiny DC-DC converter | jackinnj | Power Supplies | 1 | 28th June 2006 08:03 PM |
| any good tiny tiny tweeters? | THOR | Multi-Way | 18 | 28th June 2004 07:42 AM |
| Tiny amp | lifeonmars | Pass Labs | 4 | 12th December 2003 10:13 AM |
| Page generated in 0.09722 seconds (75.62% PHP - 24.38% MySQL) with 11 queries |
