diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   Michaelson and Austin Oddysee (http://www.diyaudio.com/forums/tubes-valves/37414-michaelson-austin-oddysee.html)
lpd 8th July 2004 02:15 AM
I have an opportunity to horsetrade for one of these amps. I have heard miced reviews regarding this company. The amp uses 8 EL34's and two 12AX'7 and rectifiers (can't remember what type). Output is rated 45 watts per channel class A. Anyone have any info on this integrated amp?
Peter
fdegrove 8th July 2004 09:07 AM
This company took over most of M&A's activities and product range:
PAPWORTH
Cheers,;)
matthias 8th July 2004 09:39 AM
2 Attachment(s)
Hello LPD,
one of my friends has used a one of these for years.
He used them with B&W 801 S1 speakers. I have listened tot his combination a lot.
I always liked the sound of the amp (although not too powerful, at least not on the 801's) and the (bizarre) looks of course.
If you could get it for areasonable price I would certainly take it!
It is the one in the picture, right?
Matt.
lpd 8th July 2004 03:12 PM
Do you think it will be enough power for 90db speakers?
Peter
fdegrove 8th July 2004 06:25 PM
More than plenty power to drive even a 84dB/m pair of speakers.
Cheers,;)
lpd 8th July 2004 06:50 PM
Well if the price is right I might jump on it.
Any ideas what this amp retailed for new? How about used?
Peter
rfbrw 8th July 2004 09:54 PM
It was Michaelson Audio not Michaelson and Austin
fdegrove 8th July 2004 10:27 PM
Not even the foggiest...
Don't think so...unless both companies existed at one point in time I've always known it as being Michaelson (Anthony) and Austin (?).
My first valve preamp was a M&A TVP-1, BTW.
Some of the designs were done by Tim de Paravicini as well, IIRC.
Later on AM joined/co-founded (?) Musical Fidelity.
Cheers,;)
lpd 8th July 2004 11:31 PM
Thanks for the help. Haven't found much info online about the amp, but I think I'll take the plunge and try it, if it doesn't work out I will just resell.
matthias 9th July 2004 02:56 PM
Hi lpd,
the amplifier is for sale at a shop near my house.
They are asking 1000,- euro for it.
So that's roughly a $1000,-.......
But the shop is a bit expensive. I guess you could get it for a bit less.
Good luck!
Matthias.
Copyright 1999-2017 diyAudio
