6gk6 tubes
6gk6 tubes
Old 8th July 2004, 01:47 AM   #1
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
6gk6 tubes
Default 6gk6 tubes
anyone here ever built an amp based on this tubes.?...datasheet seems to indicate strong similarities with 6bq5 except for pinouts...
i have 4 of these tubes, which can be used to make a pp amp..
any info or url links are welcome....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 8th July 2004, 02:44 AM   #2
audiobot is offline audiobot  United States
Default 6gk6 amps
I haven't built an amp with them per se, but I have two little amp modules that came out of an old high end television. Each has a 12AX7 voltamp/phase splitter and two 6gk6 outputs. They sounded very nice actually. I also rewired them as triode, dropped the overall feedback and tried them that way for a while, also good. Have been meaning to incorporate them into a little boombox stereo, but my to do list is just to darn long at the moment. I believe they are identical to the 6BQ5 save the pinout difference. Don't know if that helped, but in my opinion they are worth playing with.
Michael
Old 8th July 2004, 04:19 AM   #3
The-Planet is offline The-Planet  United States
Default Yup, real sleeper!
Essentially a 6BQ5 with a "scrambled" pinout, specs are identical.
The RCA's look identical in construction to their 7189's
This is a real sleeper tube, well worth constructing around.
Several years ago I rewired a single ended console amp to take them, and was very pleased.
Website
6gk6 tubesHide this!Advertise here!
Tube Noob! need help with tubes lots of tubes therapy_fan Tubes / Valves 15 29th January 2009 09:01 PM
WTT: Various tubes for 6CA4/EZ81 rectifier tubes GordonW Swap Meet 4 27th August 2008 12:37 AM
Rewiring a socket to take 6GK6 instead of 6BQ5 diamondsouled Tubes / Valves 3 26th June 2008 03:16 PM
CV428 tubes (Loktal 807) tubes FS mobyd Swap Meet 3 2nd January 2008 11:26 AM
6GK6 Ultralinear jaymanaa Tubes / Valves 14 13th December 2007 12:03 AM
