| diyAudio Sponsor | ||
I have a couple of interesting looking 6AV5GA tubes in my collection. Does anyone have any experience of using these for single ended audio applications?
So-far I have found out that they are television sweep tubes and have read somewhere that triode connected versions were sold as 6B4s ??! I have plate curves for pentode connection only although triode connection is mentioned in the datasheet. Any info would be very useful |
#2 | |
diyAudio Senior Member
6AV5 is a indirectly heated beam penthode, not really all that linear as a triode... I've never seen it used in SE amps but that doesn't mean it can't be done. However: Quote:
6A5G Cheers,
Frank |
#3 | |
Frank |
#4 |
Thanks for the info
I still fancy building something SE for all the wrong reasons really: I only have two of the tubes and I like the look of them |
#5 |
I have not delved into the details, but there was a 6B4GA?. A JAN tube made by Sylvania that was supposed to be a 6AV5GA triode strapped. I've seen pictures of them.You see them for sale from time to time. How it could ever replace a 6b4 in a circuit is beyond me!
#6 | |
It was supposedly a very good amp. |
#7 | |
cheers 316a |
#8 |
Thanks for the info everyone. Although these tube are likely to be of limited use for SE output, I would still be keen to get my hands on triode curves for them. At the moment I only have tetrode data.
#9 | |
FRANK PHILIPSE Cheers,
Frank |
| My 6AV5GA SET Amp | sorenj07 | Swap Meet | 7 | 12th April 2009 05:41 PM |
| question about 6Av5ga tubes | juanito | Tubes / Valves | 15 | 24th February 2007 12:58 PM |
| Page generated in 0.10666 seconds (77.91% PHP - 22.09% MySQL) with 11 queries |
