We91a
We91a
Old 4th July 2004, 09:47 PM   #1
powertriode is offline powertriode  England
powertriode's Avatar
Smile We91a
Hi All,
I have decided that my next project will be a WE91 copy of some sort.
I have searched this forum and rec.audio.tubes and most of the links I have come across are dead.
I have found some good sources; however; which are listed below, and will be known to many of you:-
http://www.bonavolta.ch/hobby/en/audio/300b_1.htm
http://www.bonavolta.ch/hobby/en/audio/300b_2.htm
http://www.angela.com/catalog/how-to/model.91.html
http://www.timebanditaudio.com/personal.html
http://www.fortunecity.com/rivendell...cy/Legacy.html
below is the original SP article:-
http://www.timebanditaudio.com/300b/WE91A.pdf
and below is a schematic of the real thing:-
http://www.audiosharing.com/archive/...df/No.91-A.pdf
I would rather like to build the version from SP, as this appears to be nearest to the original.
Although I am a little concerned at the lack of hum pots, or a DC filament supply.
Has anyone built one??
All comments will be most welcome, irrespective of which variant, however I am most interested in the SP version, which unlike the others, retains the 310A.
Which one did you build? What iron did you use? Which tubes? etc.
Old 5th July 2004, 12:18 AM   #2
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
The amp in the first link you posted is well known over here and was sold as a kit by the french "La Maison De L'Audiophile" in Paris.
I had a listen to it on several occasions during the early nineties while I was over there on business and must say it sounded really good.
Especially on high effeciency speakers ranging from the modest Fostex 103 Sigma (hope I have it right) through more sophisticated horn systems, even in a small theatre they used during a hi-fi show.
What's even better is that with the advent of ever better passive components the amp can easily be improved upon as the basic circuit is still one of the best 300B SE amps I know of.
IIRC the OPT was a special order design made by Partridge and was sold under the reference TK4519 by that parisian shop exclusively.
WE91 INFO
WE91 AMP
Frank
Old 5th July 2004, 01:35 AM   #3
jeff mai is offline jeff mai  Australia
jeff mai's Avatar
Default Re: We91a
Have a closer look at the original WE schematic from the link you posted. You'll see that it does not use the 310A; it uses the 6C6.
Anyway, I've built a pentode driven 300B amp and tried a few different octal pentodes as input tubes. The list:
6SJ7GT
6J7G
1620
6SG7GT
C3m (*loctal)
6AC7
6SG7
They all had their charm, but I prefered the good old 6J7G and the remote cutoff(!) 6SG7GT.
Tips:
Use the smallest plate resistor on the pentode that gives you the gain you need with your system. Everyone takes a shot at the 6J7 because of the low current and HF rolloff, but if you can live with a 47K plate resistor instead of the 90K shown, it is very good.
Use a VR tube to supply the pentode screen instead of a voltage divider or series resistor. This was the biggest improvement in my amp.
Old 5th July 2004, 12:13 PM   #4
ThorstenL is offline ThorstenL  Germany
Previously: Kuei Yang Wang
Default Re: We91a
Konnichiwa,
I have experiemnted a little with the rather more complex cathode circuit shown for the original 91A. I think you should incorporate it, with exactly the values as shown.
The original 91A/B used negative feedback in a loop to the screengrid of the first stage, this reduced hum a lot.
For a modern 91 you may need to add DC heaters to get things quiet enough.
I build a "91 Inspired" Amp based on the later J.C. Verdier designed Le Maison de l'Audiophile Amplifier (EL84 Driver, later changed to C3m). All supplies regulated. Sounded excellent and was absolutely quiet....
Link below, WARNING - Fortunecity site, popups and cookies galore....
The Legacy Poweramplifier - A "universal" DHT Poweramplifier by Thorsten Loesch
Sayonara
Old 7th July 2004, 04:27 PM   #5
Default Re: Re: We91a
Hi All,
Many thanks to all for your valued comments.
Originally posted by Kuei Yang Wang
[B]Konnichiwa,
Worthy of consideration, many thanks!
Yes, I did notice this (shock/horror!!!!!)
I had intended to use DC, and that is still the path I will likely go down.
The TK4519 is still available from Partridge, however I intend to use the TH4663, which is basically the same but cased. You have to order them and they make to order, only down side is the 10 week wait for delivery
I will get the Partridge OPTX's on order and when they come I will bread board it, and have a play.
I too noticed the orig circuit uses the 6C6; I wonder when this changed to a 310????
BTW, If you want to look at the real thing, click on this link:-
http://members.jcom.home.ne.jp/nedra/91.html
Old 7th July 2004, 08:44 PM   #6
fdegrove's Avatar
Isn't it the other way around?
IIRC the WE91 used a pair of 310As...
BTW, in case anyone's interested I can still get some Russian NOS 310A with socket and gridcap.
Frank
Old 7th July 2004, 09:06 PM   #7
Konnichiwa,
Not till the "B" version. The original WE91 shipped with 6C6, the WE 310 was not available at the time IIRC.
Interesting. How close do they sound to the WE's?
Sayonara
Old 7th July 2004, 09:17 PM   #8
fdegrove's Avatar
Ah...I see....
All the "La Maison de l'Audiophile" versions are based around the "B" version.
To my taste the Russian ones compliment the sonic fingerprint of the WE300B even better than the WE310A, i.e. it's a little dryer, a tad less romantic if you like.
Frank
Old 7th July 2004, 10:43 PM   #9
Konnichwa,
Ah...I see....
Not really. They use the same tube complement, but the circuit differs much.
Just for fun, my current state of ideaplay for a "modern" 91, complete (replete?) with feedback loop and a few other things....
Interresting. Best take this off line....
Sayonara
Old 7th July 2004, 11:41 PM   #10
fdegrove's Avatar
T.,
It looks as if there's a drawing error in the diagram:
On the 310A g1 and g2 are tied together.
Frank
We91aHide this!Advertise here!
WE91A Pentode Questions? sgerus Tubes / Valves 11 7th August 2007 03:03 AM
