my EL84 pre-amp with schematic - diyAudio
Old 2nd July 2004, 04:33 PM   #1
Default my EL84 pre-amp with schematic
pleas comment on my schematic...
any problems????
should I increase the 150v?? maybe to 200v?
I want to use a regulated power supply (VR tubes) so thats why 150 was picked.
recommendations for power supply???
dunno about SS, hybrid or tube rectified..
Old 3rd July 2004, 12:37 AM   #2
diyAudio Senior Member
fdegrove's Avatar
Hmmmm....why so complicated?
Am I correct in assuming you're trying to make some sort of mu-follower combining a choke and FET?
Why not just use a choke as a plate load, take the signal off the plate and use a VR tube to clamp the B+?
You can use the loadlines from the 12B4A if you like, a trioded EL84 is very similar...Maybe wire it for ETM as well?
Zout would be in the 1K zone if that's what you want.
Frank
Old 3rd July 2004, 01:54 AM   #3
Default ETM?
What is ETM? and what is its advantages??
Do you think a choke loaded triode EL84 would "sound" better than a triode EL84 with a MOSFET source follower in a mu configuration??
Do I get any advantages of the mu over just a choke load??
Any PSU recommendations???
Old 3rd July 2004, 09:59 AM   #4
analog_sa's Avatar
ETM?
Yes
Not really.
EL84 SEP schematic. Some questions. Cassiel Tubes / Valves 8 6th January 2013 08:42 PM
Need schematic for EL84 PSE Yarpen Tubes / Valves 7 26th December 2010 01:57 PM
Marshall EL84 20/20 schematic needed pingfloid Instruments and Amps 5 21st November 2007 09:59 PM
looking for schematic; three EL84's in PSE ? Empee Tubes / Valves 4 6th August 2007 10:30 PM
el84 quad schematic..something is wrong...? dud_wity Tubes / Valves 15 4th April 2004 04:57 PM
Copyright ©1999-2017 diyAudio
