Old 1st July 2004, 03:52 PM   #1
Smile First time builder, need advice.
I am a first time builder and I would like to build a tube amp. I am looking for the right schematic for my budget and results.
Is the 300b all that much better for the expense or can I save some money and get similar results ?
Is there a popular all around great schematic out there (Parts availablity and costs ) ?
Where is the best source for transformers ( quality and price) ?
Any tips or things to stay away from doing from personal mistakes would be great
Thanks all !
Old 2nd July 2004, 12:25 AM   #2
G is offline G  United States
G's Avatar
Default Re: First time builder, need advice.
Thanks all !
First what is your budget? Second, what is the sensitivity of your speakers? Post back and we'll go from there.
Gavin
Old 2nd July 2004, 03:12 PM   #3
Default Re: Re: First time builder, need advice.
I would like to do this for around 400.00, I thought I could build from the ground up and then if I need to I could thow some more money at it. I am finding that the big expense is transformers. It blows me away how much some wound wire costs!
I am thinking I am probably going to build some speakers in the future, but at this time I will be hooking this up to some JBL L40s.
I have been looking at some of the J.E. Labs schematics and I like the simplicity of the 300b and the PP2A3 for a first time project. It seams from there I could build on to either one.
Old 2nd July 2004, 04:34 PM   #4
G's Avatar
You will definately need to go Push Pull with those JBL's. You might think about picking up a Dynaco Stereo 70 on Ebay and rebuilding it. There are lots of new boards and parts for them available and you could pick one up for around $250 on Ebay.
Gavin
Old 2nd July 2004, 05:06 PM   #5
I am actually wanting to start from scratch. Have you ever looked at the JE Labs schematics? Do you think I will be into this a ton of money?
Old 2nd July 2004, 05:41 PM   #6
I started out with a Bottlehead.com tube preamp kit, and my first scratch-build was an SE 2A3 from JE labs (or Angela.com, since that's where I saw the schematic and bought the parts from). My speakers were/are 95-96dB sensitive though, and I don't have a very large room, so that worked out fine for me. I think it cost me roughly $500 for my first build, with the cheap Hammond 125ESE (hope I got the name right) transformers. Since then I've upgraded to One Electron transformers and changed my driver stage, so I think I have 700 - 800 in the amp now. For my first build I did go with the resistors/caps recommended on their website. If you pick up cheap R/C from say a surplus store (which is what I eventually ended up doing for some parts of the amp), you could save some money. Re-design the power supply to use SS rectification and maybe no choke in the PS, and you'll save another chunk of money, but you'll probably have a noisier PS.
Old 2nd July 2004, 05:56 PM   #7
BHD is offline BHD  United States
BHD's Avatar
Send a message via Yahoo to BHD
Hmmmm....
With that budget you'd probably be better off sticking with a push pull amp with solid state rectification.
You may be able to build the stereo version of the JE labs on that budget, but it'll be tough. The 400 dollar budget can't include the cost of tubes, since 300B's usually start at 100 bucks each. I'd say buy the output trannies and choke new, either Hammond or One Electron. Then you have to be patient and scrounge for the power tranny. I bought a new power transformer (a really hefty one) for quite a few bucks, and not a week later this really cool UTC power transformer came available on Ebay for a third the price. I bought it, and now I have an extra one for my next project, but I should have been patient.
You'll need to fabricate your own chassis and you won't be able to use super spendy "boutique" parts. Good luck!
My religion is the golden rule. The only time it's forsaken me is when I've forsaken it first.
Old 2nd July 2004, 09:11 PM   #8
Here is the thread I'd started when I was building my amp. It has lots of dumb beginner questions, and good answers from the experienced people on this board. And like I said, it's a JE Labs 2A3 design.
There are a couple of other threads on here that go through a step-by-step description of the construction, the decisions taken, and the reasons behind those decisions. I found those very helpful when building my amp, and I think you would get a lot of information that would save you time and money if you searched for those threads and spent some time looking through them.
Old 2nd July 2004, 09:24 PM   #9
G's Avatar
The least I've ever spent on a project is about $400. That is with cheap output transformers and a old power transformer that I bought on Ebay. Are you wanting to do single ended or push pull? What type of music do you listen to?
Gavin
Old 2nd July 2004, 09:34 PM   #10
G's Avatar
Oh sure! Go ahead and get Frank & Sy involved! Frank will want to regulate the AC mains coming out of the wall!! Just kidding Frank. Seriously though. You can spend as much or as little as you want to. What is your goal? $400 is not a lot of money for a tube amp project. You will spend about $200 just for good output transformers. Bottlehead Paramours are a good kit at a good price but you will need different speakers. Full range Fostex speakers are certified ear candy with SE amps:
http://www.quarter-wave.com/Project05/Project05.html
The Paramours can be found here:
http://www.bottlehead.com/et/adobesp...r/paramour.htm
You won't believe the sound from this combination. Cheers.
Gavin
First time speaker builder (please help)! idub Full Range 11 30th September 2007 06:49 PM
First time builder hack247.co.uk Multi-Way 0 29th May 2006 08:51 PM
crossover first time builder. Dannyball Multi-Way 20 1st February 2005 08:51 PM
First Time Amp Builder in Need of Help from Experts! Creelove Solid State 9 30th June 2004 04:12 PM
Copyright ©1999-2013 diyAudio
