Help with 1626 PSE Amp needed - diyAudio
Old 30th June 2004, 10:32 PM   #1
Default Help with 1626 PSE Amp needed
Hi everybody!
I just finished my latest project, a 1626 PSE Amp.
I used a 47F cathode C, though.
After a while of listening, I thought, that the bass is a little "thin".
Looking at the bode-plot I discovered the following:
What are your suggestions to improve the output?
Thanks for your input.
Holger
Old 1st July 2004, 09:13 AM   #2
Default sorry, forgot to post the bode plot
WEll, here is the above mentioned bode plot....
What do you think?
Old 1st July 2004, 05:22 PM   #3
benny is offline benny  Australia
benny's Avatar
Send a message via MSN to benny
the very first thing i noticed was that there is no interstage coupling caps. And there is no ground resistor between first and final stage.
the coupling cap and ground resistor before a stage form a highpass filter with a -6bD/octave slope with a -3dB point calculated by f=1/(2*pi*R*C)
R and C represent values of these components... i'll let you guess which one represents the coupling cap and which one represents the ground resistor.
you can also use a bit of neg feedback to help flatten out frequency response.
also try using a tone control. something simple like a baxandall tone circuit would take you not much time to put together, and will give you plenty of control over frequency response.
cheers
Old 25th October 2004, 02:20 PM   #4
bigbulb is offline bigbulb  Canada
Hammond 125E can't give you enough flat response, no air gap between EI lamination, try 125ESE.
Here's a new info about 1626, distortion curve,
http://www.audiohobbyist.com/projects/1626.htm
cheers,
FS: 1626 Tube Amp, Van Alstine pre, tubes, crossover. xecluded Swap Meet 1 30th April 2009 07:27 AM
FS: Darling Tubes 1626/8532 RockysDad Swap Meet 1 13th February 2009 02:07 AM
Darling 1626 amp rca9449 Tubes / Valves 9 7th October 2008 05:33 PM
1626's watt? hhocean Tubes / Valves 5 28th April 2005 09:13 PM
FS... Tubes for double Darlings (1626 & 8532) RockysDad Swap Meet 2 26th January 2005 07:00 PM
Copyright 1999-2017 diyAudio
