SE el84
SE el84
Old 29th June 2004, 02:34 PM   #11
benny is offline benny  Australia
benny's Avatar
Send a message via MSN to benny
also, 1M would be fine... difference if you used a 470k resistor is you would get a slightly lowered gain from the first stage, and slightly less resistor noise.
sorry correction... just looked at the scheme and saw that this resistor is after the coupling cap... yeah, i'd say 1M looks pretty sus to me too.
also, i just looked at the f/back loop, and maybe the 100ohm resistor is what it was meant to be, becuase the shunt resistor is only 150ohm... still this is pretty unusual and i don't see where the designer is coming from if it was intended, and is not just a mistake... still, this will give an unusualy high amount of feedback...
SE el84Hide this!Advertise here!
5W EL84 drive EL84 SE Audio_idiot Tubes / Valves 31 31st May 2012 09:38 PM
El84 Pp Tobruk Tubes / Valves 1 1st May 2007 01:05 PM
EL84 PP Diy. Pls help me!!! BigOx Tubes / Valves 24 11th June 2006 07:09 AM
el84 help inquisitive Tubes / Valves 14 26th March 2005 08:19 AM
