wsw siemens ultralinear 815 410 G !!?!
Old 26th June 2004, 06:22 PM   #1
BUCKOI is offline BUCKOI  Yugoslavia
Talking wsw siemens ultralinear 815 410 G !!?!
first of all hello to all,
i just obtained two never used wsw siemens ultrallinear power amps, model 815 410 G from 1963!
They were made for rack mounting but the problem is the output transformer which is modeled for 100V lines!
How can i change that and use the amps with regular speakers??
The other question concerns the fact that there were no tubes in the amp (Ecc84 and El34), so it seems that i have to get new ones. Any suggestions?
cheers
Old 26th June 2004, 08:18 PM   #2
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Welcome to the forum.
I doubt that the amplifier used ECC84, ECC83 is far more likely.
The 100V line thing is more of a problem. Have a look at the connections on the output transformers to see if they can be set for conventional loudspeakers. If the transformers can't be connected differently, they will need to be replaced. Fortunately, transformers for EL34 amplifiers are very common. You need to know whether the transformer has ultra-linear taps. If it has five primary wires, with two going to each output valve, it's ultra-linear, but if there are only three, then the valves are probably operating as pentodes.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 26th June 2004, 11:38 PM   #3
SHiFTY is offline SHiFTY  New Zealand
SHiFTY's Avatar
Wow, pics please!
How do you know they were never used?
Also, are there any taps on the transformers themselves? You might want to have a close up look at them.
Old 27th June 2004, 12:54 AM   #4
Layberinthius is offline Layberinthius  Antarctica
Surely you could simply place a cheaper matching transformer post-output pre-speaker?
Ailbeit it might be better off replacing the output trafos afterall they /are/ PA :\ which are usually of a lower quality.
I'd say your best bet is a Hammond replacement as you might be able to take measurements of the old one and give an exact match: Hammond
Old 28th June 2004, 02:21 PM   #5
sorry about the tube number, my typing error.
since i didn't have time to picture the amp properly here's a scan from the papers.
Old 28th June 2004, 02:35 PM   #6
..and the circuit diagram.
Old 28th June 2004, 05:21 PM   #7
EC8010's Avatar
It's a Williamson driver with ultra-linear EL34 grafted onto the end, and should be good for 20W. For lowest distortion, you're looking for a 6.6ka-a 25W transformer with 43% UL taps. There should be loads of them out there, it's a very common output configuration.
wsw siemens ultralinear 815 410 G !!?!Hide this!Advertise here!
Ultralinear pse mark_titano Tubes / Valves 1 5th November 2007 11:54 PM
6V6 Ultralinear gingertube Tubes / Valves 12 4th May 2007 08:56 AM
2E24 ultralinear mach1 Tubes / Valves 4 13th August 2005 09:41 PM
PP-1c as Ultralinear Charles BL Tubes / Valves 1 28th January 2003 04:52 AM
Ultralinear vs SE Petman Tubes / Valves 46 10th January 2003 07:10 PM
Copyright ©1999-2017 diyAudio
