Flashing EL34
Flashing EL34
Old 4th July 2004, 11:21 AM   #21
Tube_Dude is offline Tube_Dude  Portugal
Tube_Dude's Avatar
Fdegrove, unfortunatly for me, you are wrong. In the PCB where you have the volume and balance blue Alps pots you also have two 2N1711 transistors in the signal path as Tube_Dude said.
As usually i only talk when i know what i'm talking about...
Cheers
Jorge
Old 13th March 2007, 01:40 AM   #22
imfos is offline imfos  Portugal
Reading your post about the Jadis Orchestra stating that, and i quote, "the Jadis Orchestra has a transistor gain stage at the input and if you take it out of circuit the sound become much better" because "the Jadis Orchestra is in fact a hybrid amp..." i thought maybe this is an easy thing one can DIY. Can you please give me some information about it? Thx
Old 13th March 2007, 03:31 AM   #23
gingertube is offline gingertube  Australia
I have a parallel pushpull Triode Mode EL34 amp running +475V rails.
I tried lots of different EL34s in it and concluded that the "Winged C" Svetlanas were the best. They easily outperformed Ei and various Chinese EL34s and were slightly bettr than JJs.
Ian
Old 13th March 2007, 05:17 PM   #24
Tube_Dude's Avatar
Olá , Imfos
Yes ... Its a thing one can Diy , but that depend of your technical knowledge
The issue is to bypass the transistor gain stage ( 3X , if I remember correctly ) and to connect the volume pot directly to the 12AX7 grid ...
In any doubt, email me...
Jorge
Old 13th March 2007, 11:10 PM   #25
Olá Jorge
I'm afraid my technical knowledge is not enough to fully understand your tip.
I'm far from being a technician and only with full instructions (preferably with pictures) i fell encouraged to do the job.
Thxs anyway for your reply.
Imfos
P.S.- I'm still not allowed to e-mail you
Old 14th March 2007, 12:14 AM   #26
Tube_Dude's Avatar
Olá Jorge
Olá Imfos
Email adress removed by member request - the mod team
Jorge
Old 14th March 2007, 04:43 PM   #27
kevinkr's Avatar
Flashing EL34
Hi tube_dude, you might want to ask a moderator to remove your email address from this thread before every spambot on the net finds it..
In future using something like "tubedudeatblanketyblankdotpt" might be a little safer..
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 14th March 2007, 06:36 PM   #28
Tube_Dude's Avatar
Thanks Kevin, I will do it...
Jorge
Old 14th March 2007, 06:41 PM   #29
anatech is offline anatech  Canada
anatech's Avatar
Flashing EL34
Hi Tube_Dude,
Done.
"Just because you can, doesn't mean you should" © my Wife
Old 14th March 2007, 06:45 PM   #30
Tube_Dude's Avatar
Originally posted by anatech
Hi Tube_Dude,
Done.
Hi Anatech
Lightning fast , as always ...
Thank you!
Jorge
Flashing EL34Hide this!Advertise here!
tube is flashing and glowing very bright! pho_boi Tubes / Valves 8 9th February 2006 09:16 PM
7591s flashing on start-up? mr mojo Tubes / Valves 8 11th October 2005 08:33 PM
Tube flashing safetyman Tubes / Valves 15 7th September 2005 02:26 PM
Flashing light in time to the music? SkinnyBoy Music 6 10th February 2003 09:42 PM
how? --> making a flashing led multiplexor Parts 31 19th January 2003 12:33 PM
