Flashing EL34
Flashing EL34
Old 28th June 2004, 09:37 AM   #11
karma is offline karma  Canada
karma's Avatar
ok here's one with the light on working on a power supply
for the filament
there new out of the box
gas? i have just a little
http://www.karmaelectronics.org
Old 28th June 2004, 11:30 AM   #12
electropt is offline electropt  Portugal
electropt's Avatar
The tubes I have right now are Ei Yugo, they are not very well rated... The amp I have them on is a Jadis Orchestra, my first and last comertial tube amp, the next one will be DIY
The SED EL34 and some other are for sale at eBay, I got my matched quads for US$58.90 including shipping for anywere in the world from this auction here but not the gold pin ones...
Here is a pic of my quite nice sounding amp:
The rest of the system: Monitor Audio Studio 6, AMC CDM7 (CDP with CDM4 transport and modular output modules), Rega Planet 3, Rega Eos phono stage, Straight Wire Maestro ICs, and Cable Talk 3.1 speaker cable (to be upgraded SOON!).
Old 28th June 2004, 11:37 AM   #13
Tube_Dude is offline Tube_Dude  Portugal
Tube_Dude's Avatar
Olá electropt!
Have you remarked ,that the Jadis Orchestra has a transistor gain stage at the input and if you take it out of circuit the sound become much better.
The Jadis Orchestra is in fact a hibrid amp...
Um abraço
Jorge
Old 28th June 2004, 12:26 PM   #14
electropt's Avatar
Caro Jorge,
Obrigado pela dica, tenho de ver essa situacao. Ja teve a oportunidade de comprovar o efeito antes/depois?
Cumprimentos,
Hugo
Dear Jorge,
Thanks for your tip, I have to take a look at it. Have you had the oportunity to hear the result of such mod?
Best regards,
Hugo
Old 28th June 2004, 12:30 PM   #15
Tube_Dude's Avatar
Originally posted by electropt
Dear Jorge,
Yes...i have one of this babys. The sound inproved a lot.
Specially the perceived dinamic range.
Um abraço
PS: Se quiseres contacta-me por mail.
Jorge
Old 28th June 2004, 12:40 PM   #16
electropt's Avatar
Originally posted by karma
my amp did the same thing. cheaper to replace the quad
than to leave it like i did. 2 weeks ago my amp finally died. only would have cost me $60 for new tubes now its $200 for part's and tube's
you shoulds see it when it really short's
could this happen it could or maybe not see pic
It is comforting to know that the two pairs of power tubes are protected from arcing or over-bias operation by two .315mA fuses mounted inside the chassis.
Old 30th June 2004, 12:40 AM   #17
electropt's Avatar
Dear Sir,
Thank you for your interest in our products.
The Orchestra is a hibrid. The preamp part is solid state.
Cordially,
Jadis
----- Original Message -----
To: jadis@jadis-electronics.com
Sent: Tuesday, June 29, 2004 2:49 AM
Subject: Jadis Orchestra
Dear Sirs,
Could you please tell me if the Jadis Orchestra integrated amplifier is a hibrid or all tube?
Thanks in advance.
Kind regards,
Hugo
Shame on Jadis!!!
I never read in the catalog that it was a hibrid... Jadis is no more!
Bahhhhhhhhhh
Old 30th June 2004, 12:54 AM   #18
karma's Avatar
ahh u still got a nice amp just mod it
Old 30th June 2004, 10:40 AM   #19
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Hybrid?
I don't think so....Unless they changed it recently all the JA Orchestras I've seen so far had no semi-conductors in the direct signal path whatsoever.
The way it is setup is 1/2 12AX7A as a voltage amp, followed by the other 1/2 12AX7A as a phasesplitter/driver for the PP EL34 or KT90s for the Reference models.
BTW, as it is fully P2P wired except for some parts of the PS, tracing the signal path is pretty straightforward.
Frank
Old 30th June 2004, 11:23 AM   #20
electropt's Avatar
Originally posted by fdegrove
Hybrid?
Fdegrove, unfortunatly for me, you are wrong. In the PCB where you have the volume and balance blue Alps pots you also have two 2N1711 transistors in the signal path as Tube_Dude said.
And I guess the actual production units still are hibrid based on the repply I got from Jadis. Mine was from early 1998 (SN: 0770).
It has a very nice P2P construction and simple wire scheme.
It has PCBs in the HV power supply in the source selector and in the volume/balance/input gain stage.
I guess its almost a Jadis
Hugo
PS. The lousy pictures were made with a crapy CMOS camera, please take that into consideration. Or else you can give me a new good one
Flashing EL34Hide this!Advertise here!
tube is flashing and glowing very bright! pho_boi Tubes / Valves 8 9th February 2006 09:16 PM
7591s flashing on start-up? mr mojo Tubes / Valves 8 11th October 2005 08:33 PM
Tube flashing safetyman Tubes / Valves 15 7th September 2005 02:26 PM
Flashing light in time to the music? SkinnyBoy Music 6 10th February 2003 09:42 PM
how? --> making a flashing led multiplexor Parts 31 19th January 2003 12:33 PM
