Tube Pre-Amp < 0
Tube Pre-Amp < 0
Old 25th June 2004, 01:21 AM   #11
Eli Duttman is offline Eli Duttman  United States
I took a look at the STA1. It's a line stage with gain. There are a number of things I don't like about the unit. For starters, it takes 0.2 V. of I/P to produce the full 5 V. peak to peak O/P documented. That's 10% of a CDP's 2.0 V. I/P. You would have a difficult time controlling the listening level. BTW, the 2.0 V. RMS a CDP produces is 5.66 V. peak to peak. Ignoring the STA1's sonic virtues or lack thereof, the unit would mate well with a phono stage that has 35-40 dB. of gain.
At 0.4 V. of I/P for full power O/P, the S5 integrated amp is quite sensitive. Still, that's only 1/2 as "touchy" as the STA1 is. The S5 might have a "hair trigger" volume control with a CDP, while the STA1 is almost certain to have the problem. The S5 will mate well with a phono stage of 40-45 dB. of gain.
Eli D.
Old 26th June 2004, 08:00 AM   #12
zobsky is offline zobsky  India
zobsky's Avatar
build a 12b4a preamp, ..shouldn't cost you much at all (the power supply tranny (and choke, .. if you use one) will make up the bulk of the cost
"Not everything that can be counted counts, and not everything that counts can be counted." - Albert Einstein
Old 26th June 2004, 08:55 AM   #13
bequerel is offline bequerel  Norway
Have a look at this:
http://www.hagtech.com/clarinet.html
This guy knows his business:-)
Thanx!
Tube Pre-Amp < 0Hide this!Advertise here!
need diy tube preamp (line-stage) recommendation and general tube advice Musiclover4 Tubes / Valves 16 18th May 2013 04:19 PM
FS tube tuner, Active filter kit, tube amp, amp3 Josephjcole Swap Meet 9 20th July 2007 05:05 PM
SS or tube voltage amplifying stages in an amp with tube output? ray_moth Tubes / Valves 14 4th July 2007 04:09 AM
tube driving the same tube - whats the collective word? zobsky Tubes / Valves 3 13th June 2005 07:47 AM
