using Mosfets as diode in PS - diyAudio
Old 21st June 2004, 04:10 PM   #1
le´flu is offline le´flu  Germany
Default using Mosfets as diode in PS
Hi all,
while surfing i found this page in the net:
http://peufeu.free.fr/audio/alim_mos_diode/
what do you think of using mosfets in powersupplies to minimise ripple?? Anyone who tried this, any comments or HP`s where one discribes a test with Mosfets like this??
Greetings Ulf
Old 21st June 2004, 04:52 PM   #2
It won't work.
There is a "parasitic" diode formed by the substrate that is conductive in the reverse direction. So this device would conduct in *both* directions, with a threshold voltage of ~4 volts in one direction and ~0.7 volts in the other.
MOSFETs are used as "synchronous" rectifiers, where the device is turned "on" when current would flow in the direction of the parasitic diode. But in this case, the IR drop across the channel is lower than the threshold voltage of the parasitic diode.
EDIT: When I wrote the above, I didn't see his schematic at the bottom of the page where he added extra diodes to prevent reverse-biasing the MOSFETs. So perhaps it could work after all.
Old 21st June 2004, 05:06 PM   #3
ok shure, but the author of my linked article uses the fet after the rectifierbridge, so reverse current will be inhibited.
But the measuring diagramms show less ripple.
There would be much less noise on the powersupply.....
correct me if i´m wrong
greetings Ulf
Old 21st June 2004, 05:37 PM   #4
It seems like it may be worth trying. Let us know how it sounds.
Old 21st June 2004, 05:48 PM   #5
hi,
er..yes, but which MOSfet can i take, the author doesn´t mention one type of fet. So do i have to use a special quality fet or just one for high voltage??
I think i have to collect some data sheets
Old 22nd June 2004, 03:31 AM   #6
diyAudio Senior Member
fdegrove's Avatar
I think the diagrams are only simulations, not actual measurements.
However, the lesser amount of ripple is likely due to the higher internal resitance of the MOSFET.
The author clearly states that the voltage drop is rather high and that the project is not really economical.
Nowadays, SiC Schottky diodes are available at reasonable prices considering the context of a one off DIY project.
They'll probably fall even more within a few years.
There are other alternatives that work very well such as the hybrid tube/silicon diode FW rectifier that has been discussed extensively on this forum before.
Still, I won't stop you from trying the FET rectifier scheme out if you feel so inclined.
Frank
SMD diode ID please Perry Babin Parts 6 4th February 2014 07:50 PM
diode bridge - 10000uF cap - diode tube - small cap - HV+ engels Tubes / Valves 5 29th January 2008 11:16 PM
hybrid power supply: diode bridge into diode tube engels Tubes / Valves 8 24th September 2007 10:18 AM
What is this diode for? lumanauw Solid State 15 6th January 2007 06:14 PM
n/p Mosfets vs depletion mod mosfets marcello7x Car Audio 6 4th October 2006 06:01 AM
Copyright ©1999-2017 diyAudio
