need help finding tube make - diyAudio
Old 19th June 2004, 07:50 PM   #1
karma is offline karma  Canada
karma's Avatar
Arrow need help finding tube make
the 2 tubes are 12ax7. the one with the big plate sounds great
and can run with a low b+ but there is no information on it. can anyone from just looking at it tell me what make it is?
any tube freaks out there
thanks.........
Old 19th June 2004, 10:45 PM   #2
SHiFTY is offline SHiFTY  New Zealand
SHiFTY's Avatar
Well the one on the right is a matsushita, made in japan, not too bad at all. Looks like the one on the left is an old mullard. Does it have a row of small codes on it anywhere?
Old 19th June 2004, 11:04 PM   #3
karma's Avatar
no totally clean of everything but on the plate there is 2 x's
scratched on it
Old 19th June 2004, 11:15 PM   #4
mmm the one on the left looks like Mullard due to the smooth plate cut and colour tone.
The closest I've got is a pair of mullard EC90's and they both have "3" scribbled on the plates.
Old 19th June 2004, 11:17 PM   #5
jamesjung21's Avatar
I need a picture with better resolution to identify the one on the left...
I need to have a look at the bottom as well...
If the glass on the bottom is crystal clear, then it might be a Japanese tube, or a british one, either Trigon, or Brimmar (of their latest production).
If the left one has a diamond mark <> on the bottom, then you've got a gold..... TFK!
I can see the left one having double mica on the top... Does anyone know which brands made tubes with tripple micas?
Old 19th June 2004, 11:46 PM   #6
karma's Avatar
sure give me a few minutes
Old 19th June 2004, 11:53 PM   #7
karma's Avatar
Default .
best i can do camera has a problem with the focus
Old 20th June 2004, 12:22 AM   #8
diyAudio Senior Member
fdegrove's Avatar
If the plates have horizontally spaced ribs AND there's no acid marking on the glass to be found it could very well be a SYLVANIA ECG U.S.A. 12AX7A from the Seventies made for export exclusively.
The profile of the tube fits the bill but it's hard to be sure from just a picture no matter how well taken.
Frank
Old 20th June 2004, 12:39 AM   #9
karma's Avatar
well it was worth a try anyway
thanks for the help
how easy to make tube amp? space2000 Tubes / Valves 4 28th June 2008 11:24 PM
hi, want to make tube amp + small loud speakers electrofan Introductions 5 17th April 2008 06:15 AM
CCS in Otput Tube Cathode - Does It Make Sense? lcsaszar Tubes / Valves 45 20th August 2007 08:17 AM
how to make tube amp sound layback and mellow? jj2 Tubes / Valves 28 10th April 2006 03:47 AM
anyone know of a kit to make tube night light? Christof Tubes / Valves 7 13th March 2005 07:47 PM
Copyright 1999-2017 diyAudio
