| diyAudio Sponsor | ||
Hi!
I recently aquiered an obviously Vintage OPT from a flee marked. It's probably been used in a radio. I have measured it to be of a 5K:8 ratio. The windings have many paper-interleavings, and is impregnated in wax. It really looks like a (relative) quality opt. I think I want to use it in a SE guitar amplifier with a 6V6. One interesting thing though, is that it apparently does not have an Airgap, I can see no paper-interleaving between the E and the I parts of the core. So, was it normal to use Parafeed in the Radio days? How can I find out if the OPT can pass any DC current? Thanks; -stigla |
#2 |
There are fancier ways to do it, but my inclination would be to rig it up with whatever small tube I had laying around (like an EL84), in triode for simplicity, then run a signal to the grid and see what comes out. If you've got a test bench with basic stuff like power supplies, sig generators, clip leads, and a scope, this should take less than an hour.
"...we stumble and get up, we are sad, confident, insecure, feel loneliness and joy and love. There is nothing more; but I want nothing more.” - Christopher Hitchens 1949-2011 |
#3 |
Doesn't have to have paper in the core, usually all the Es and Is are grouped together rather than interleaved as in an AC transformer. Maybe a piece of cardboard between the Es and Is to add a little gap but it's not necessary if the current is low, which may very well be on a 6V6 SE OPT.
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing. The key to being a successful Audiophile: "I reject your reality and substitute my own!" |
| FS: Vintage Tek Scope | Jimmy D. | Swap Meet | 0 | 12th June 2008 01:00 AM |
| Getting a vintage amp to work | DeadSpeaker | Tubes / Valves | 69 | 8th August 2007 02:39 AM |
| Vintage diy | IsakAlexander | Solid State | 5 | 7th October 2006 03:01 PM |
| vintage restoration | tenderland | Tubes / Valves | 2 | 28th June 2005 07:08 AM |
| vintage cd-80 | honsten | Digital Source | 1 | 31st July 2004 07:29 PM |
| Page generated in 0.07938 seconds (74.65% PHP - 25.35% MySQL) with 10 queries |
