I look for a correct driver stage - diyAudio
Old 10th June 2004, 10:31 AM   #1
nonos is offline nonos  Hungary
Default I look for a correct driver stage
Hello,
I built my own designed tube amplifer. You can see this below.
I think the driver stage not to good for the KT66. I don't know what kind of stage do I use in this. Parallel triode , SRPP, mu follower? Which is the best choice?
Can you suggest the correct driver stage schematic?
I thougth that I try the cathode follower between the first stage and the KT66. What do you think this is good idea?
Thanks,
Nonos
Sorry that you can something but my english is not to good. :-(
Old 10th June 2004, 10:47 AM   #2
Frank Berry's Avatar
KT66/6L6 is easy to drive but you'll need some gain in the driver stage.
You may want to look at the schematic in the following link.
http://www.bonavolta.ch/hobby/en/audio/6l6_1.htm
Frank
Old 10th June 2004, 12:10 PM   #3
Default Look for a cathode follower schematic for KT66
Hi
I know this schematic. It was the first version of my amp, but I had some problem with this.
If you use 6L6 in this setting , the dissipation will be to big for 6L6. You need to use 6l6GC but it was very expensive for me.
The sound of this driver stage is very hard so I didn't like it.
I would like to heard soft but determined sound. Therefore I know the cathode follower stage.
Old 10th June 2004, 02:54 PM   #4
Jax is offline Jax  Sweden
The KT66 needs some 18-19V RMS for full output. A triode with a mu around 20 will have a voltage gain of around 14 rendering an input sensitivity around 1.5V RMS for full output.
Say one triode in an ECC82 with 100k plate and 2.2k on the cathode with a cathode bypass and with Vb = 400V would do the trick if you have no feedback.
If you do not want a cathode bypass you will need a triode with higher gain (and harder sound in my opinion). I'm not a friend of ECC83 with output voltages over a few volts.
Another option would be a mu-follower using a couple of ECC82-type triodes.
BTW, the Linde schematic uses an ECC81 in an SRPP, in my opinion a very bad choice.
Jan
Old 10th June 2004, 09:06 PM   #5
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
cheap solution-ECC88 single or paralleled
better solution-say any gutsy triode (or trioded pentode) with lotsa gain and adequate IST
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 11th June 2004, 05:13 AM   #6
Default mu follower
What do you think about this driver stage?
I would like to try it in my amp, but I have to change the setting of the ECC83. The power supply for this tube is about 400V and I would like that the power supply will be same in bouth triode in the driver stage.
What is the correct current for this setting? Where does it sound in the best?
Thanks,
Old 11th June 2004, 11:00 AM   #7
SHiFTY is offline SHiFTY  New Zealand
SHiFTY's Avatar
Well I really liked a 6SL7 cathode follower driver stage on my SET. It increased the bass, made the music more alive and made it sound like a proper amplifier!
One thing I would suggest is putting 200 ohm grid stopper resistors in front of each ECC83 grid, this stops parasitic oscillation.
I don't know the best operating values, suggest what is used in your schematic.
24 or 24a as driver in 2 stage..? JandG Tubes / Valves 3 30th December 2008 12:43 AM
Need a serious PP driver stage Fuling Tubes / Valves 19 30th October 2007 08:08 PM
Output stage biasing, with the driver stage andrew_whitham Tubes / Valves 0 19th May 2007 11:14 AM
Mu stage driver lndm Tubes / Valves 19 22nd September 2006 02:57 PM
VSE PP1 driver stage Andrewbee Tubes / Valves 4 28th November 2004 01:35 AM
Copyright 1999-2017 diyAudio
