Pls. recommend an ideal schematic for a tube rectified preamp (line stage only) that should work very good with rotel 1075 ss amp. They say a foreplay circuit should work fine but i dont have the circuitly. Would appreciate your help? Thanks alot!
#2 |
The Foreplay is relatively high gain. SS power amps "typically" have a sensitivity of less than 2 V. for full power. That means the O/P of a CDP will drive the amp into clipping. So, you need a buffered volume control with approx. unity gain.
A "simple" cathode follower fills the requirement. A thread discussing this subject appeared on this "board" quite recently.
Eli D. |
#3 | |
diyAudio Senior Member
GAVIN'S 5687 FOLLOWER A little bit of self-promotion never hurt anyone...so: TUBE RECTUMFRIER A LA RIGUEUR... The linestage is a White Cathode Follower preceded by a volume control... That one can drive a SS amp input impedance and a mile of I/C cable...so to speak...Just what the doctor ordered. Cheers,
Frank |
#4 |
Will the 5687 schematic be advisable on this pairing?
#5 | |
Frank |
#6 | |
Gavin |
#7 |
Thanks guys! Based on ur recommndations, anybody out there wants to share the schematics?
#8 |
#9 |
Here you go.
Gavin |
#10 |
How do you attain a maximum output impedance of 200 ohms to a tube rectified preamp? Would appreciate your help. Thanks again.
| learning tube rectified psu | milen007 | Tubes / Valves | 26 | 21st September 2008 12:28 PM |
| Looking for a PCB / kit for a bipolar tube rectified PSU | luvdunhill | Tubes / Valves | 10 | 16th August 2007 01:23 PM |
| PSU question? Going tube rectified | sbelyo | Tubes / Valves | 47 | 2nd June 2006 09:27 PM |
| How much capacitance for tube rectified PSUs? | JoeBob | Tubes / Valves | 3 | 26th May 2003 01:13 AM |
