diyAudio Sponsor
Old 7th June 2004, 04:45 PM   #1
G is offline G  United States
G's Avatar
Default 6V6 Parafeed?
Hi All,
Been playing around with a Parafeed design for a 6V6 SE amp. Anyone familiar with this topology? Do any gross mistakes stand out?
Gavin
Old 7th June 2004, 05:46 PM   #2
The high pass pole formed by C3 and R5 should be tuned to about 5 Hz. Therefore you can use a smaller value than 2.5 muF. FWIW, a PTFE part as C3 would be very transparent.
You can save weight and expense by replacing the loading choke and B+ decoupling filter on the 5687's plate with a CCS.
The 6 V. of bias for the 5687's grid is easily obtained from a stack of 3X red LEDs under the cathode. Using LEDs eliminates the bypass cap.
Eli D.
Old 7th June 2004, 05:58 PM   #3
G's Avatar
Hi Eli. DO you think a C4S will handle 15mA without a heatsink?
Gavin
Old 7th June 2004, 07:45 PM   #4
I really don't know. Ping VoltSecond on the Bottlehead "board".
Eli D.
Old 7th June 2004, 08:18 PM   #5
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Looks fine, although you have more frequency response in C3 than you can possibly have in the OPT (face it, 2.5Hz transformers are notoriously hard to come by ) and triode mode 6V6 will have real low power. Fine if ya got some horns or something though I s'pose.
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Old 7th June 2004, 09:30 PM   #6
G's Avatar
I went 1.5 years with a EL84 SE amp in triode mode and it worked fine for me. My Fostex full rangers are about 96 dB 1w/1m. Two watts works really well with them. Thanks for the reply though.
Gavin
Old 8th June 2004, 12:03 AM   #7
Sch3mat1c's Avatar
Alright, should work fine then.
Old 8th June 2004, 12:26 AM   #8
diyAudio Senior Member
fdegrove's Avatar
Gavin,
For best sonics I'd lower the value of C3 to 0.47µF which will still pass all the lows you'd ever need without the higher time constant of the big ******.
Instead of the MKP cathode bypasses you may want to try out Black Gates there instead, they'll take up less room and sound better too.
If you don't need the gain I'd even ommit C2 or at least give that a try. It should yield a little less distortion due to local degenerative feedback.
Frank
Old 8th June 2004, 01:26 AM   #9
G's Avatar
Thank you Frank, Sch3mat1c and Eli. I will do as you suggest Frank. With such a high plate load the cathode bypass on the 5687 isn't really needed is it?
Gavin
Old 8th June 2004, 01:31 AM   #10
fdegrove's Avatar
Hi Gavin,
Not for the gain you want anyway...I'd actually overlooked the choke load but give it a shot just the same.
EDIT: Using Eli's LED bias scheme would even be better sounding still...CCS could be added later on as the proverbial icing on the cake if you like that approach.
Frank
Parafeed Circuit cdeveza Tubes / Valves 25 27th February 2011 09:13 PM
2a3 parafeed alexg Tubes / Valves 2 17th November 2007 10:47 AM
to parafeed or not to parafeed that is the question nhuwar Tubes / Valves 63 28th February 2007 12:29 PM
OTL or parafeed? Jaime Tubes / Valves 14 11th December 2005 07:22 AM
Parafeed Brett Tubes / Valves 14 7th April 2003 12:53 PM
Page generated in 0.10451 seconds (76.64% PHP - 23.36% MySQL) with 11 queries
