| diyAudio Sponsor | ||
Did they make 5 volt Damper diodes back in the good ole days? I would like to try a couple in the PSU for my linestage.
Gavin |
#2 |
diyAudio Moderator Emeritus
(As they say your side of the pond
I can't imagine an application for one, so I'm sure nobody made any. |
#3 |
I mean a damper diode like a 6au4 with a 5 volt filament.
Gavin |
#4 |
The application note for the 6D22S indicates it will run on 5 or 6.3 volts.
Tech Note for 6D22S I got 6 receintly on e-bay for under $5 ea. otherwise hard to find. Enjoy; Doug |
#5 |
diyAudio Senior Member
Since you I assume you have 5V AC and this is for a linsestage, why use a FWB rectifier? You'll have about 7V DC. Add a dropping resistor to arrive at 6.3V and you can use small dampers such as the 6S2/EY86s? Cheers,
Frank |
#6 |
Actually I was thinking of using a couple of tube damper diodes to make the bipolar PSU for my buffered linestage. They are supposed to be much quieter than anything else in power supply rectification. I didn't want to run the diodes off of the heater winding so as to avoid any interaction between the tube heaters and the PSU rectification. That may sound a little silly but that is how I'm looking at it. Are my concerns unfounded?
Gavin |
#7 |
G,
Use a Chinese 5AR4 for the tube half of your hybrid bridge. The forward voltage drop in a 5AR4 is not much greater than that in dampers, particularly at low preamp currents. UF4007s will take care of the SS half of the bridge nicely.
Eli D. |
#8 |
If it's only a line amp where the current drain is not too high, 5 volts might well be enough for a 6v3 heater anyway.
Best-ever T/S parameter spreadsheet. http://www.diyaudio.com/forums/multi...tml#post353269 |
#9 |
somwhat OT; but anyone care to reccomend a damper diode that has good sound, and likely to be somewhat available in NOS from both UK and USA manufacturers?
(No duodecar bases, but 'strange' filament voltages and top-caps are ok. Oh, a slow warm-up would naturally be good too.
check out my avitar and go easy on me ok? :-) |
#10 |
Majestic,
The 6AU4 is a very safe bet in damper diodes. Damper diodes turn on very slowly; a 5AR4 is faster. SED currently offers the 6D22S; it uses a tiny cathode cap and a Magnoval socket. You can get a feel for what's available by searching AES' (www.tubesandmore.com) web site for "damper".
Eli D. |
| What's the biggest full wave damper diode? | leadbelly | Tubes / Valves | 12 | 10th September 2008 06:39 PM |
| diode bridge - 10000uF cap - diode tube - small cap - HV+ | engels | Tubes / Valves | 5 | 29th January 2008 10:16 PM |
| hybrid power supply: diode bridge into diode tube | engels | Tubes / Valves | 8 | 24th September 2007 09:18 AM |
| TV Damper Diodes | CarlyBoy | Tubes / Valves | 5 | 19th November 2006 09:20 PM |
| Damper Diode Musings | Eli Duttman | Tubes / Valves | 12 | 21st February 2005 05:08 AM |
| Page generated in 0.11093 seconds (79.08% PHP - 20.92% MySQL) with 10 queries |
