5v Damper Diode? - Page 2 - diyAudio
Old 7th June 2004, 01:19 PM   #11
igormak is offline igormak  Russian Federation
igormak's Avatar
Originally posted by G
They are supposed to be much quieter than anything else in power supply rectification. [/B]
Hi!
G, seems to be it's a good idea to use 6d22. It has some advantages. Svetlana still manufacture them. Read the article by Erick Barbour, pls.
http://www.svetlana.com/docs/TechBul...hnoteNo52.html
Rgs, Igor.
Old 7th June 2004, 02:18 PM   #12
G is offline G  United States
G's Avatar
Originally posted by igormak
Hi!
Rgs, Igor.
I probably will use them in my next project. Either them or some 6au4s. Thanks.
Gavin
What's the biggest full wave damper diode? leadbelly Tubes / Valves 12 10th September 2008 06:39 PM
diode bridge - 10000uF cap - diode tube - small cap - HV+ engels Tubes / Valves 5 29th January 2008 10:16 PM
hybrid power supply: diode bridge into diode tube engels Tubes / Valves 8 24th September 2007 09:18 AM
TV Damper Diodes CarlyBoy Tubes / Valves 5 19th November 2006 09:20 PM
Damper Diode Musings Eli Duttman Tubes / Valves 12 21st February 2005 05:08 AM
Copyright 1999-2017 diyAudio
