| diyAudio Sponsor | ||
How much gain and current is needed to drive a 300B? I would like to try it with a 7044 in one stage if possible.
Gavin |
#2 |
Depends on your operating point. You want to be able to swing something more than the standing cathode-to-grid voltage for class A or AB1. You want a source impedance low enough to keep the rolloff from the time constant (pole) formed by the driver source impedance and the input capacitance of the 300B at least a decade higher than the dominant pole. If you're running the 300B in a greater-than-unity-gain output stage, be sure to account for the Miller input capacitance, too.
Bottom line: the 7044 will do just fine in an appropriate circuit.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#3 |
I don't know what a 7044 is but a 300B takes about 40 (actually I haven't seen a circuit this low) to maybe 80V peak drive. To run from a .25Vp signal source you'll need as much as 160 gain. This can only be done in one stage with a pentode. Typical circuits use a 12AX7 (I wouldn't, not much drive capacity), an 'AX and a low-gain, high output driver, or two 6SN7 stages.
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing. The key to being a successful Audiophile: "I reject your reality and substitute my own!" |
#4 | |
#5 |
Ya... just overestimating to give the maximum amount needed. Of course, double that once or twice if you want NFB (typically not done to triode amps, certainly not 300B's
Tim
#6 | |
It isn't neccessary to find some exotic drivers. Some of good 12Ax7 like Sylvania (5751) or Mullard,... are enough exotic choice.. A lot of informations you can see on www.hinedfi.com (USA/ENG site) in the next days. Sound of 300B design often depent a lot on primary/secunary relation of output transformer....
www.hiendfi.com www.hajdinjaklabs.com |
#7 | |
I recently heard it driven by a 2A3 - it had unusual power, dynamics and surprisingly - bass. |
#8 | |
A Gary Pimm style CCS load, with its built in mu follower, allows you latitude in the choice of gain triode. The 6n1p, the 12AV7, and the 6J6 are possible candidates. IIRC, GP indicated that the pentode (6AU6)/FET variation of his CCS is particularly good sounding in front of a power triode "final".
Eli D. |
#9 |
A lot of money for one.
#10 | |
diyAudio Moderator Emeritus
Just the high's were a bit ragged. |
| 300B driving 845 | otto88 | Tubes / Valves | 4 | 7th June 2009 07:47 AM |
| Tube designs: 45 driving 45/2a3/300b? | Veniogenesis | Tubes / Valves | 4 | 23rd April 2007 06:59 PM |
| driving 845 push-pull with a signal from a 300B SE stage | Antonio Tucci | Tubes / Valves | 1 | 20th February 2007 08:04 PM |
| * 35 watt * 300B SE = super 300B + Class A2 | rick57 | Tubes / Valves | 4 | 13th July 2005 04:18 PM |
| Page generated in 0.12606 seconds (73.23% PHP - 26.77% MySQL) with 11 queries |
