#31 |
You series diodes (with voltage equalizing resistors across them) to form a diode with a higher working voltage. For example, two 1000V diodes in series would form the equivalent of a 2000 volt diode. The only difference between that composite diode and a "genuine" 2000V diode is that the composite will have two times the voltage drop, i.e., 1.4V rather than 0.7V.
If there's a sucker born every minute, where do the rest of them come from? |
#32 | |
diyAudio Senior Member
In the circuit as shown by George they're used in a voltage doubler so the 1N4004 being a 400V 1A device wouldn't have a chance when left on its own there, hence the 2 diodes in series making it essentially a 800 Fv device at 1A and 800V PIV but with a Fvd of 1.4V iso 0.7V as SY has pointed out. Cheers,
Frank |
| A good tube amplifier power supply | Jean-Paul_2 | Tubes / Valves | 23 | 18th June 2009 11:19 PM |
| Tube power supply | duderduderini | Tubes / Valves | 1 | 9th December 2008 04:33 AM |
| I clonning Milbert BAM230/235 Car Tube Amplifier Supply | ANALOG GUY | Car Audio | 7 | 6th June 2008 03:04 AM |
| 900v. 100ma. Power supply for 813 tube amplifier | noyan | Everything Else | 0 | 5th June 2004 07:48 AM |
| Power Supply and VR tube help! | AudioGeek | Tubes / Valves | 24 | 28th February 2004 12:16 AM |
