900v. 100ma. Power supply for 813 tube amplifier
Old 4th June 2004, 01:17 AM   #21
Eli Duttman is offline Eli Duttman  United States
Spec sheets look interesting, Eli. Do you know where these diodes can be purchased?
Tube Builder (www.tubebuilder.com) carries the SiC Schottkys.
The 1200 PIV parts are costly, but the 1 A./600 PIV parts are under 2 USD each. You can build a bridge rectifier with UF4007s in the ground legs and SiC Schottkys in the B+ legs that will be very quiet, as the Schottkys block the PN reverse recovery spike. IMO, containing costs while retaining performance can't be bad.
Eli D.
Old 4th June 2004, 06:50 AM   #22
noyan is offline noyan  Turkey
Send a message via Yahoo to noyan
Default SE813 AMPLIFIER SHEMATIC
HERE THE SHEMATIC OF 813 TUBE AMPLIFIER.
http://homepages.ihug.co.nz/~rwillis/alex/
Old 4th June 2004, 12:38 PM   #23
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Default if you have to regulate
this is a close approximation of the Horowitz and Hill HV regulated supply with a voltage doubler. i have used this supply for a HV lab supply -- instead of a reference I use a DAC, etc., etc.
you might have to adjust the compensation values for your particular situation.
the bottom of C3 should be grounded.
Old 4th June 2004, 04:22 PM   #24
Default power supply
OK. What is Q2 ?
Old 4th June 2004, 06:19 PM   #25
jackinnj's Avatar
Default Re: power supply
Originally posted by noyan
OK. What is Q2 ?
Take a look at the parametric search engines at International Rectifier or Fairchild Semiconductor -- Fairchild, in particular, should have out their 1200 Volt Super MOSFET. (They talked about it on one of their web-seminars recently.)
The supply I have built only goes to ~400 volts, I am using IRFPG40's.
Old 5th June 2004, 01:03 AM   #26
georgehifi is offline georgehifi  Australia
georgehifi's Avatar
Send a message via MSN to georgehifi
Look at the voltage doubler power suppy at`s used in my 805 SET at Dave (planet10) so kindly posted for me, it works well as is simple.
http://www.diyaudio.com/forums/showt...threadid=33992
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 5th June 2004, 03:47 AM   #27
Default IXTP3N120 1200V/3A SUPER MOSFET
If i use: IXTP3N120 1200volts / 3A high voltage super mofset in my shematic and remove IRF740 and BUX48. Then, 900 volts will not be a big deal for such strong mosfet. ???
Old 5th June 2004, 11:57 AM   #28
jackinnj's Avatar
Default Re: IXTP3N120 1200V/3A SUPER MOSFET
The circuit I have shown would also require that the values of the caps in the doubler be capable of handling more than 450V for 900V out -- thus you would use a pair in series -- i.e. 680uF/350VDC.
The Ixys transistors are available from Digikey (if anyone is wondering) they are $6.09 ea.
Old 5th June 2004, 12:14 PM   #29
benny is offline benny  Australia
benny's Avatar
Send a message via MSN to benny
i was just wondering... i had a look at george's power suply, and saw the two diodes in series on it, and it made me think how many times i have seen this used... so maybe i'm getting a little off topic, but what is the advantage of putting two diodes in series? is this to do with the switching noise or something??? anyone on this post know?
cheers
Old 5th June 2004, 12:28 PM   #30
Default serial diodes
I am wondering too.
900v. 100ma. Power supply for 813 tube amplifierHide this!Advertise here!
I clonning Milbert BAM230/235 Car Tube Amplifier Supply ANALOG GUY Car Audio 18 8th June 2017 09:03 PM
A good tube amplifier power supply Jean-Paul_2 Tubes / Valves 23 18th June 2009 11:19 PM
Tube power supply duderduderini Tubes / Valves 1 9th December 2008 04:33 AM
900v. 100ma. Power supply for 813 tube amplifier noyan Everything Else 0 5th June 2004 07:48 AM
Power Supply and VR tube help! AudioGeek Tubes / Valves 24 28th February 2004 12:16 AM
