Difference between CK6528 and 6528A ? - Page 3 - diyAudio
Old 1st June 2004, 11:47 AM   #21
On Hiatus
SY's Avatar
FWIW, I used a pair of them in PP with 400V B+, 1250 ohms plate-to-plate, and got a solid, low-distortion 90 watts.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 4th June 2004, 08:02 AM   #22
Hi again
OK - thanks again. The tubes I have are for sure NOS. They came from Kastup Airport in Copenhagen. I got them from a person who works there. He got a lot of tubes when they decided to get rid of some old stuff.
About building an amp with these. I have a set of output trannies made for 300B PP. The problem is that i dont know the load they represent. Does someone know if it would fall in a range that is uaseble for these tubes? I also have a set of output trannies made for 4 x 6550C Paralel push pull. Would these be better?
Thanks again, Peter
Old 4th June 2004, 10:31 AM   #23
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
For Class A PP, you need about 2k - 2k5 anode to anode for one pair of 6528 triodes (one 6528 - it's a dual triode), and for SE a 2k transformer. If you ratio a 5k transformer (that's probably what your 300B transformers are) by connecting an 8R load across the 16R winding to give a 2.5k load you will lose a little bit of power in the excessive DC resistance of the secondary and the HF performance won't be as good as a purpose-designed 2k5 transformer, but bass may be better. If you feel that SY is too far away to send 6528 for proper crushing, the UK is nearer...
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 4th June 2004, 11:22 AM   #24
On Hiatus
SY's Avatar
Default The 6528 Disposal Center
EC, please, you can't seriously want to pollute your lovely country with toxic waste like that. Be a patriotic European and direct all such garbage to less civilized lands like the US. It's a sacrifice for us, but sacrifice for the good of others is our motto.
Old 29th June 2011, 04:39 PM   #25
fooeywuffle's Avatar
Default 6528 Tubes
I have found no difference with any of them, 6528, 6528A, or 6528A/B
How much difference 0.22 vs 0.33 cap? pengboon Tubes / Valves 1 1st July 2007 10:07 AM
difference between 1 and 2 androtaker56 Car Audio 9 14th November 2005 12:36 PM
Difference between CDM 4/19 and CDM 4/19/31 bezobraznia Digital Source 1 28th October 2005 10:08 AM
I2C/I2S,what's the difference??? Leolabs Parts 2 18th April 2005 01:20 PM
What's the difference? 2.83V/1m - 1W/1m 1Time Everything Else 5 10th February 2003 03:54 AM
Copyright 1999-2017 diyAudio
